Question about JVC Cybercam GR-DX95 Mini DV Digital Camcorder
Screen hi playback is fine but when you switch to record the screen goes blank cheers simon
  • Craig A Dec 28, 2008
    I have the same problem and unfortunately do not have my instruction manual. When the camera is set to record there is no image displayed. It often shows the message 'remove lens cap' when the cap has already been removed so I thought there may have been a sensor that was not working or something.
  • 983 Answers
Check whether the recorded video is working or not ...
if it is not working then the ccd sensor might have got damaged ...
if it is working then there will be some problem in the firmware ..
just try giving reset ....
if problem persists then visit the technician.........
Posted on Mar 31, 2008
Purchased this recorder about 6 months ago. Now it can't turn off via the hold switch.A very sleek and convenient piece of apparatus. When I try again after 2 days it works fine but when i try to turn...
It is possible there is an intermittent contact, but I don't believe there is anything to worry about.
The HOLD slider does not turn off the recorder. It only turns the keyboard off and the display off as well. The clock keeps running.
A simple test?
Start a RECORDing operation and slide the switch to HOLD.
(In my VN-1800 the keyboard goes dead, but the display stays on.)
(In my DS-330, the keyboard goes dead and the display goes off.)
If I slide the switch to HOLD during a PLAYBACK operation, it keeps going until the file has finished playing. Then it goes blank.
May 31, 2011 | Olympus VN5000 (512 MB 3005 Hours)...
Hi, i have recntly been given a canon mv5 camcorder, however, when I switch it on and start recording all I can see is a blank screen or a blank viewfinder. Sound can be heard during playback but it...
the damge could have occured to the lens gears inside of the cam, try to tap it while recording, very gently, its very fine ..other options is to reset the systen unit again and check..for further info check out this link.... http://www.canon.co.uk/For_Home/Product_Finder/Camcorders/Digital/MV5/index.asp
Oct 25, 2009 | Cameras
Blank Screen When Recording
hi, if you have an on screen display in camera mode you should check into the lens to see if your shutter or iris is opening.
Jul 23, 2008 | Panasonic NV-GS17 Mini DV Digital...
Hi dileep solve it
check whether the recorded video is working or not ...
Apr 15, 2008 | Motorola Mobility RAZR V3
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
VHS plays with green tint
I would try to take him out with a laser gun,but remember he has a licence to kill to.
Jan 25, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Playback won't work
needs to be cleaned and possibly tension adjustments. most cases this will fit it but the video heads could need replacing.
Sep 14, 2007 | Sony Handycam DCR-TRV245 Digital-8 Digital...
JVC Cybercam GR-DX95 Mini DV Digital Camcorder Logo
55 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
