Question about Abit A17 Guru Motherboard
Abit A17 motherboard error codes
I recently cleaned the CPU fan on a Abit A17 motherboard and now it won't start. I had error code 9.0., now it gives me error code F.O. Does anyone know whats up?
  • abstech Apr 01, 2008
    tried both as well as resetting the bios, no go.
  • davidDM047 Oct 16, 2008
    I recently upgraded the power supply on my A-17 and while I was at it, I cleaned the build up of dust from fans and heat syncs. When I turned it on the lights to all 4 hardrives lit and all fans etc. ran but nothing beyond that. Error code read 9.0 and the F.0. Time for a new processor, motherboard... ?!?
    Thanks in advance for your insght to this collective problem.
    Genius:
  • 1,913 Answers
Check your ram and also clean yopur processor case reattach it.
then restart pc.
Posted on Mar 31, 2008
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Have an Abit A17 motherboard that stops booting with a check sum error. Code on the digital readout is either IA or 1A, neither of which is in the manual. Any idea about this?
Press delete as the system boots up and go into BIOS Setup.
Change boot sequence so that your machine starts with the CD/DVD ROM disk.
Boot from the CD/DVD and do a clean installation.
Jul 15, 2011 | Abit AI7 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
C115 motorola vodafone unlock code
Can not give unlock codes please read terms of service - http://www.fixya.com/terms
Apr 05, 2009 | Abit A17 Guru Motherboard
Latest motherboard error codes
sound has a ecco and in the code digit is is 2.0 and it has a alarm on it when u start the PC it is like a ambulance noise.
i hope u can tell me how to fix the PC
Mar 25, 2009 | Abit A17 Guru Motherboard
Motherboard beeping
Error code 26 could mean faulty or not properly seated RAM or video card. Can also mean keyboard error. Error 5D is an audio problem. Hope this helps.
Feb 08, 2009 | Lexmark T430 BAR CODE CARD (26H0395)...
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
A17 wont boot
ok what board is it
#then check the manual for error post code error af
if not try another card liek a pci one
or agp one
Jun 06, 2008 | Abit AI7 Motherboard
Hey anyone can help me with some info
Well it will not hurt you're board if that's what you want to know. Depends what devices you have plugged into the board. If you're running 4 serial ATA SATA's. Two CD/DVD drives. A floppy drive & an AGP 8x graphics card. The 400w should do just fine. (You can never run too high a PSU source).
I'm running 4 serial ATA 7200rpm SATA's, 2 DVD-ROM's, a floppy drive. 1 PCI-E graphics card. Four, 4" case fans. Skt 939 Dual core 4200+ CPU & my 550w has been stable for over 2 years.
Have a great weekend!
Mike
May 30, 2008 | Abit A17 Guru Motherboard
Computer wont boot
This is a memory detection fault. Remove and reseat memory, try one at a time. If no joy then reset the bios at the JBAT1 terminal put jumper from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart your pc hopefully then set time and date in standard bios settings and check hard disk is recognised.
Jan 24, 2007 | Abit A17 Guru Motherboard
Abit A17 Guru Motherboard Logo
1,284 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
