Question about Frigidaire FSE748GF Dryer
Problem for Frigidaire FSE748GF Dryer Brown marks on clothes - What could the problem be and how do you fix it.
    Brigadier General:
  • 4,088 Answers
If the clothes have a 'burned' smell, likely, the air flow through the machine is restricted and getting too hot. Vacuum out the exhaust hose and the outside vent of lint. Reach inside the machine's air outlet pipe and vacuum all that you can reach. Remove the lint filter and wash it in hot water and detergent to remove fabric softener deposits. Vacuum below the lint filter opening as far as you can reach and inside the door cavity (be careful of sharp edges!). Hope this helps!
Posted on May 16, 2010
With our front-load Frigidaire clothing dryer our
Follow this link to see the parts breakdown for your unit. It sounds like you are correct about the problem. Thank you for providing the correct model number...:). You can also call this company for additional help or information.
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=FSE748GFS0&model_id=125229&manufacturer=Frigidaire
Feb 10, 2010 | Frigidaire FSE748GF Dryer
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
Frigidaire FSE748Gf dryer squeaks all the time now when drying.
Drive Belt. It may work for a long time, and the squeak may go away, but the belt is worn and needs replacing.
Aug 13, 2009 | Frigidaire FSE748GF Dryer
Brown lines on clothes (whites and lights) from the dryer
you need the top seal replaced it is wore and clothes are getting stuck in the front seal...
if you are handy you can do it yourself...
Jun 17, 2009 | Frigidaire FTF2140FS Front Load Washer /...
FSE747GESI Frigidaire frontload dryer brown stains
I have the feeling that faded from the clothes .. so that there are brown marks .. or .. we have washing machines ber rust .. until that happens
Jun 16, 2009 | Frigidaire FTF2140FS Front Load Washer /...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
You will need to replace the drum seals. Not too expensive if you do it yourself.
Post your model number and let me know if you need assistance on how to replace them.
Apr 06, 2009 | Frigidaire FSE748GF Dryer
This is a pretty common problem with these Frigidaire dryers. Crice hit it right on the head when he said the clothing is getting stuck between the guides and drum. The upper and lower felt guides need to be changed. This is not one of the easiest jobs. The top and front panel have to come off and the guides are glued on with high temp. adhiesive. The old guides have to be scraped off. Part numbers for the upper and lower guides are 5303937139 -(upper) 5303283286 -(lower). Catriver...post back
Jan 13, 2007 | Frigidaire GLER642A Electric Dryer
Brown streaks on clothes
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
141 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
