Question about eMachines ET181003R PC Desktop
My computer shut down now i press the power button to turn on it has no light and the fan runs for a second and then nothing
    Brigadier General:
  • 4,088 Answers
Either the power supply has failed or there is an overload in the machine that is causing the supply to shut down. The second possibility may require professional help to find and repair the problem. Good luck!
Posted on May 16, 2010
Lenovo laptop shut down and will not turn on. Tried removing all power and holding down power button but didn't work. When I press power button the te button lights up for a few seconds then goes out. ...
disconnect the adapter +battery HOLD THE POWER button by 30 seconds aprox, this trick is by eliminate all ESD.
Try again connecting the adpater +battery, if work is o.k
If the problem persist, connect only the adapt and see if the computer work, if does , connect the battery, if work is o.k .if doesnot.
The battery is faulty, RUN the software diagnostic with the adapter and see what going on inside of computer, the power supply inside can be faulty or the battery.
As a last trick, open the battery take out the small battery for CMOS, by 20 seconds. And turn on the computer can be TURN on.
God bless you
Jun 23, 2013 | Computers & Internet
When i turn on the computer, the fans run like mad, but nothing else runs. I just replaced the hard drive. When i pressed the power buttons, the intake fans (think center low profile) fun at full...
Hi and Welcome to Fixya!
for your issue here, first try to do a power drain. Make sure the machine is shut down and unplug it from the power source. then press and hold on the power button for about 10 seconds, then try and turn on the machine normally. If this does not work, try to do a "ram dance".
To do a ram dance (if you could replaced the hard drive then definitely you can also do this), just unseat the memory sticks of the desktops and put them back in (also you could switch there places).
Try to turn the machine normally. I'd say this works about 75% all the time =)
Hope this helps!
Takasashi
Jul 13, 2011 | IBM ThinkCentre M51 PC Desktop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
eMachines ET181003R PC Desktop Logo
120 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
