Internet Access System recovery disk used, now com port 3 cannot be opened. Modem according to system status is okay. Cables checked and known to be good
    Genius:
  • 1,913 Answers
Check your modem to pc connection again
if u got pro try toreset your modem with your isp settings and also reinstall your modem driver
Posted on Mar 31, 2008
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Dear all. We use twin modem V.3266 of Motorola to connect data from PLC A&B to SCADA via fiber optic cable and Mux (NEC 6000), but now two modem are usually display training status, and data don't...
Hi Mr Q,
You would need a big check-up on:
1. PLC (Comm card - Prosoft ?)
2. Modems
3. Multiplexers
4. Optical Cables
5. RS232 Cables
6. Comm Port Spliter (MOXA?)
7. SCADA System (Oracle Database ?)
Please let me know your above check-up results so I provide further help.
TBT
Oct 26, 2010 | Arris V3229 (6209526200030) Modem
Do i have un install my speed touch modem to install netgear dg834v5
Hi, please note that speedtouch modem and DG834G router will not work together. Rather DG834G will replace the speedtouch modem. Remove the speedtouch modem and follow the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually http://192.168.0.1).
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 05, 2009 | NetGear DG834G Router
I connected adsl cable but no internet connection. My old external modem still works ok, so no issue with telephone line. Do i need to configure router?
Yes - find http address to access the new modem via your computer (something like http://192.168.0.1 - varies according to model) using Internet Explorer. Go to where you can put in your username and password for your ISP (your Internet supplier), and put them in. This will be something like your.name@tiscali.co.uk (or whomever) and the password you would use to access your ISP email or webpage for your internet account. The new modem needs to know who to connect to and how to get in to your authorised inernet supply.
Sep 07, 2009 | NetGear DG834G Router
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
Motorola wr850g
1) Are you sure you're connecting to YOUR wireless network? From my own house, I can access 5 different wi-fi networks, 3 of them unsecured. I've even logged into two of them, unintentionally.
2) Check all of your cabling connections that they are tight and
secured. This includes the cables from the wall to your modem,
between the router and modem, and from the router
to your PC. Ensure that your LEDs are not lit Red or not at all.
3) Ensure that you are using Ethernet cables and not telephone
cables between the router and PC. Ethernet
cables use a wider RJ-45 style plug using 8 wires where
telephone style plugs use the smaller RJ-11 style plug using 4 to
6 wires.
4) Ensure that your Ethernet adapter is enabled. Check the System
Tray at the bottom right of your display to see an icon that looks
like a monitor. You can click on this to see the status of
your Ethernet adapter. Also in Control Panel > Network and
Dial-Up Connections, you can examine the state of your Ethernet
adapter.
5) Firewalls. Your desktop firewall(s) may be blocking your internet access. Check them.
6) You may not be completely blocked (only web traffic - port 80 - blocked). Go to Start > Run and type CMD. At the DOS prompt, type ping 192.168.1.1 (should be the default IP address of your router). If you get a response, your PC is talking to the router. If you get "timed out", then they are not talking, for some reason. If successful, try pinging an external address, something like ping www.fixya.com, and see what happens.
Oct 21, 2008 | Arris WR850G Router (DHWR850G)
I need a restore disk for gateway computer
From Gateway website:
Q: What if my Gateway System Recovery CD/DVD is lost, missing or damaged? A:
  • For computers shipped after November 1, 2004 and until January 2005, a patch needs to be installed. Download the patch through our FTP site at ftp://esupport:vImvF88@ftp.gateway.com/pub/hardware_support/drivers/apps/medialess/Create_DRV_APPS_CD_Update.exe. After the installation of this patch, the option to create the drivers and applications CD is available from the Start menu under Programs. However the operating system (OS) CD\DVD must be requested by e-mailing customer service.
    Note: Replacement of the operating system CD may be at a cost according to your warranty status.
  • For computers shipped between January 2005 and June 2005, the option to Create my Drivers-Applications CD(s) is already available under Programs. The operating system CD\DVD must be requested by e-mailing customer service, and may be at a cost according to your warranty status.
  • For computers shipped after June 2005, an operating system CD\DVD is included and the option to Create my Drivers-Applications CD(s) is in System Recovery. Access the program from the Start menu under Programs. This backup process through System Recovery allows you to create the applications and drivers CD\DVD as many times as needed. If the operating system CD\DVD is lost, missing, or damaged, e-mail customer service to inquire about a replacement. Please note that replacement may be at a cost according to your warranty status. If all CD\DVD's are needed, e-mail customer service to inquire about a replacement. Please note that replacement may be at a cost according to your warranty status.
Send them an email with model number from tag at the back of the computer and ask for recovery CD.
Sep 04, 2008 | Gateway Computers & Internet
Hi I have a Toshiba A10 notepad and it's suffering a few problems. First of all, it says a error message 797 when trying to connect to the Internet. I've checked Modem Properties and also Modem in use,...
hi,
goto device manager, right ckick the modem and uninstall it. then press F5 or press scan for hardware changes tool button. then go for the new device install with the driver of the modem available with you. if this doesnt work, let me know
thank you
Jul 29, 2008 | Computers & Internet
No Internet Through the Router
If changing from a dial-up connection, see warning at bottom. Troubleshooting Steps 1. Connect your computer directly to the modem, without the router. If you cannot access the Internet, contact your ISP. 2. Reconnect the router, modem, and computer as they were before Step 1. Can you log on to the router? If not then: 1. Check that all cables attached to the router and computer are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot light status, as explained in the router manual. 3. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual. 4. Check if the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue this document. If the adapter is not NETGEAR's, contact the manufacturer. 5. Power off the router. 6. Power the router on again. 7. If you still cannot log on to the router, then do a hard reset on the router, as described here: http://www.fixya.com/ThreadView.aspx?thi... 8. If you still cannot log on to the router, Contact NETGEAR: http://kbserver.netgear.com/kb_web_files... . 3. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 7.) 4. If a dynamic IP address is discovered, go to Step 8. 5. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 8. 6. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 8. 7. If the Smart Wizard does not find an IP address: 1. Power off the router. 2. Power off the modem. 3. Power on the modem. 4. Power on the router. 5. Go back to Step 3. 8. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access! 9. If the page does not display in a minute, check here: http://www.fixya.com/ThreadView.aspx?prd... . 10. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the modem, router, and computer, in that order ? waiting for each to completely reboot before rebooting the next. 11. If the modem's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are not greyed out, then settings for a dial-up connection are being used. Warning: If you are a dial-up user converting to a cable or DSL connection, some software will not work when both types of configuration are present. Configuring your new connection may stop your dial-up connection from working. You may have to configure to connect one way or the other.
Feb 19, 2006 | NetGear RP114 Router
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
