Question about HP Compaq nc6120 Notebook
Control panel does not show bluetooth icon. Why?
HP nc6120 notebook: control panel does not show bluetooth icon. Why? Device manager does
    Novelist:
  • 83 Answers
Run services.msc (which is the service management tool)
You should see a Bluetooth Support Service, set this to start and then have it automatically start with windows as well.
Bluetooth control panel application: bthprops.cpl
Bluetooth listed in my actual control panel.
However you may need to reinstall BT again and check for the properties of it.
Please check the steps and let me know if it works.
Posted on May 16, 2010
How do i turn on bluetooth for hp envy23 computer
Go to device manager. Enable device. Also click on bluetooth icon in system tray and make sure that its on. Also go to control panel and see if there is a icon there. If so check that.
Aug 19, 2014 | HP Envy 23-1070 All-In-One Desktop PC with...
Were is bluetooth button on nc6120 laptop
Complete Details For HP Compaq nc6120 PC Notebook
Click Here Below Link:-
http://www.google.co.in/url?sa=t&rct=j&q=how%20is%20nc6120%20laptop%20for%20bluetooth%20function&source=web&cd=6&ved=0CFUQFjAF&url=http%3A%2F%2Ftim.id.au%2Flaptops%2Fhp%2Fhp%2520compaq%2520nx6110%2520nc6110%2520nx6120%2520nc6120.pdf&ei=qKcsUYWlJYGErQfaiYCgBA&usg=AFQjCNGkdQ6lvx3bDXarL5ey-Mtw8aWdMA
Feb 26, 2013 | HP Compaq nc6120 Notebook
How to activate bluetooth in a leptop
Check to see that the laptop has a Bluetooth adapter installed. Click on the "Start" menu in the lower-left corner of the desktop. Click on "Control Panel." Click on "Performance and Maintenance" and then on "System." Click the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Look for a small blue icon that says "Bluetooth Devices." Click on the "+" next to it to expand the menu. There should be at least one Bluetooth device listed. This indicates that your laptop has a Bluetooth adapter. Turn on the Bluetooth device by locating the physical or software switch that activates the adapter. Check the outside edge of the laptop for a button or switch that is labeled "Bluetooth," shows a picture of the Bluetooth icon or is labeled "Wireless." Turn this to the "On" position. If no physical switch exists, check the function keys on top of the keyboard. Look for one that shows a wireless symbol. This may look like a small antenna with waves radiating out from the top. Hold down the "Fn" or "Function" button and press the corresponding function key until the computer indicates that Bluetooth is turned on. Locate the Bluetooth icon in the system tray in the lower-right corner of the desktop. It will match the appearance of the Bluetooth icon you located in the Device Manager. It may have a red symbol in the center that indicates that the Bluetooth is turned off. Right-click on this icon and choose "Start the Bluetooth Device" from the menu. Test the Bluetooth by connecting a Bluetooth device. Right-click on the Bluetooth icon in the system tray. Use the "Quick Connect" option or follow the Bluetooth setup wizard accessed through the "Add a Bluetooth Device" option. Hope this helps.
b>
Dec 13, 2012 | Lenovo 3000 N100 Notebook
How to enable bluetooth on my hp pavilion dv7
link to driver if not installed alredy
if driver installed :
Check that your PC has a built-in Bluetooth device by consulting its user guide. If it does not, you'll need to buy an external receiver often referred to as a "dongle" and connect it to a spare USB port.
Ensure that your wireless and Bluetooth receiver is turned on. Touch the antenna symbol next to your PC's volume control. It will turn blue when it's on and amber when it's off.
Go to the "Control Panel" from the start menu and select "HP Wireless Assistant" if you're using XP. You'll need to go via "Network and Internet" if you're running Vista or Windows 7.
Make sure your Bluetooth adapter is enabled. If you get a warning that it's not, click on "Windows Device Manager," right-click on your Bluetooth device and select "Enable."
Go back to the "HP Wireless Assistant" window and press the "Turn on" button next to the Bluetooth icon if it's not already showing as being activated. Your Bluetooth device is now on and you're ready to connect to another enabled unit.
Jul 26, 2011 | HP Pavilion dv7-1132nr Notebook PC
HP Compaq nc6120 Notebook my problem ok with network adapter,prblm on other devices - ethernet controller, mass storage controller, pci simple communication controller
u need to download and install its device driver to used it. go to my computer right click and choose properties, then go to hardware and select device manager and you will all uninstall driver with ? mark. means u need to install it.... go to www.hp.com - support - driver put your loptop model and download all appropriate driver in there and install it... just click the exe, its automatic
Jun 22, 2011 | HP Compaq nc6120 Notebook
What can i do because my compaq nc6120 has failed to enable my bluetooth
Go to the hp website and download the latest drivers for the bluetooth
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=447347&prodTypeId=321957&prodSeriesId=447346&swLang=8&taskId=135&swEnvOID=181
if this doesnt work, check that the bluetooth device is diplayed in the device manager:
start>my computer > right click >properties > device manager.....under network controllers... or somewhere there....
lastly check that the bluetooth button is pressed on the laptop.
let me know how you get on
Mar 19, 2011 | HP Compaq nc6120 Notebook
Its not recognizing my sd card reader
Make sure you can see the Secure Digital host controller and
Texas Instruments PCI GemCore based smartcard controller in the Device Manager. If its missing, re-download the drives from HP.
If you are trying to use a SDHC Memory Card in the reader,
you will need updated Win XP TI drivers as the ones on the HP site
do not support the newer memory cards.
This goes for the nx5000's nx6110's nc6120's and nc6320's.
Updated XP TI drivers are needed
May 06, 2010 | HP Compaq nc6120 Notebook
I installed new window so i need blutooth driver
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=447347&lang=en&cc=us&prodTypeId=321957&prodSeriesId=447346&taskId=135
go to above website chose your opearting system and download the drivers
Dec 29, 2008 | HP Compaq nc6120 Notebook
Bluetooth activation
Check first if you hve the bluetooth hardware. go to device manager under conrol panel (classic view). Check and see if yu have bluetooth listed under device manager, If none, your unit is only BT ready but not capable.
If you can see it under device manager, turn on the wifi switch on the laptop. Find the Bluetooth icon on the notification area(looks like a blue circle with the BT icon), right click on it to enable.
Hope this helps.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Enabling bluetooth
Are you sure that bluetooth is installed? You should be able to look in the Device manager, usually listed under Network Adapters to see if there is such a device. If so, it is usually enabled using the HP network configuration icon in the Tray (where the clock is on the right hand side of the taskbar).
Apr 06, 2008 | HP Pavilion zd8000 Notebook
HP Compaq nc6120 Notebook Logo
326 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
