Question about Electronics - Others
Yorx compact home audio system model 200(karaoke machine) plugged it in was working and played fm radio on it. plugged it in again to use it and the bass speaker was not working just the small speakers were. I have no manual or remote for this unit as i got it at a garage sale.
simplemitch
  • 752 Answers
SOURCE: TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Posted on Sep 13, 2007
SOURCE: Venturer AVR2000, home theatre system
I have same system and had same problem until I connected digital audio coax to receiver from digital source.(orange port). Also try making the center front speaker much louder volume setting than all other speakers. hope it helps.
Posted on Feb 19, 2008
VOTIT
  • 2071 Answers
SOURCE: RCA audio system,and three disc.
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Posted on Jun 15, 2008
SOURCE: Insignia® - 75W DVD/CD/HD Radio
Connecting an external AM antenna solved the problem. The internal antenna (if there is one) is useless.
Posted on Sep 09, 2008
SOURCE: no sound in karaoke machine
check all the power transistor and resistor in the amplifier section, check also the power supply for correct voltage. if all the components are good next step is check the speaker. leaky capacitor makes your amplifier a popping sound output. i hope this may help you... good luck...
Posted on Jan 07, 2009
How do I program the Bluetooth connection to my phone
without knowing your phone model and make no one in the world will be able to answer this question for you especially when your question is in a section for The Singing Machine Singing Machine SME399 Dual Cassette Karaoke System w/AM/FM Radio Boombox!!!!
Nov 11, 2014 | The Singing Machine Singing Machine SME399...
Hello. I just bought a yorx compact Disk AM/FM dual alarm clock radio at a garage sale and don't know how to set the time and alarms. Is there a guide that I can follow?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Apr 30, 2011 | Audio Players & Recorders
I have a fleco karaoke machine the problem is that when you put a cd in the machine the word error appears what do i do please help
Hello. These karaoke machines can be a pain in the neck in that not all karaoke CD's work in every machine. Check in your manual to see which CD's are recommended. I had the same problem until I went to the home page for my karaoke machine and found the exact CD's that would play. Good luck with it. J.
May 22, 2010 | Sony STR-DB930 Receiver
After unplug, all audio inputs including FM radio do not work. but CD/DVD works fine. Bose321 system
Pull it all out again and start again, starting with just the bass module and left and right speakers, plug in the fm radio antenna, and tune it in if necessary. work with the radio first, then when you get that working, plug all of the other speakers in, then try a dvd, after that continue plugging in any other connections you may have i.e set top box etc.
Good Luck!
Jan 10, 2010 | Bose 3·2·1 II System
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Parts for YORX Grandeur radio
most door latches can be replaced with this one, take a look and see if it matches yours
http://mcmelectronics.com/product/DISTRIBUTED-BY-MCM-A4U66-/32-5710
Mar 13, 2009 | Audio Players & Recorders
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Electronics - Others Logo
127 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
