Question about Moen T2153BN Brushed Nickel Brantford Single Handle Posi-Temp Pressure Bala
Removing flow restrictor from Moen Brantford posi-temp shower he
I have a new Moen Brantford posi-temp shower fixture. I need to know how to take out the flow restrictor in the shower head which appears to be pressed into the shower head and is the color green.
  • 8,197 Answers
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
I have a posi temp faucet that has been installed for 6 years but never used. Now i have the project completed and have no water pressure thru the shower head. The sink has lots of pressure and is on the...
Have you disassembled the shower head to see if it has a flow restrictor in it. If it does you can remove it and any aerator type screens. Hope this helps. Thanks
Dec 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen Posi-Temp Shower Handle removal
I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Moen posi-temp valve with little pressure
no,, they are set with water savers, they only flow aprox 2.5gpm this is the top flow,, if you have it more on hot you will get less flow bings it is temp control and won't let you burn your self,, nice thigs the government does,, the only other thing you could do is go back to the old style 2 or 3 handle diverters, but we all know nobody wants them anymore, good luck
Apr 03, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
I have a Moen Shower Fixture and the plastic handle on the water/temp control broke. How can I find the appropriate plastic handle for replacement?
Take a picture of the fixture and then take the plastic handle to Ace orI HD or Lowes and see if they have a match
If they do not have it ask clerck at ace if there is a plumbing specialty store and see f they have it
if not contact Trayco company Florence Sc
they have the largest supply of spare parts in the country
good luck
Jan 04, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen T2153BN Brushed Nickel Brantford Single Handle Posi-Temp Pressure Bala Logo
2,184 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
