Question about Motorola Mobility ROKR E6 Smartphone
Not recieving calls
I download some ring tones after that I am not recieving any calls but i can make calls, its as the ringer is off but its not
  • 343 Answers
Sometimes things we download from the internet have virus format the cell phone or restore to factory settings
Posted on May 16, 2010
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
My philips cd135 cordless does not ring when recieving in coming calls what is the solution.
Your phone is prob on Ringer Off mode. Press menu and then scroll down to Personal Set, press menu and Handset Tone will appear on display, press menu and Ring Volume will appear on display, press menu and then scroll to select volume, low, med or high. Do not select ringer off.
Jan 02, 2010 | GE Cordless Phone & Answering Machine...
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Cant get message alert to shut off when volume is loudest
you will need to assign the ring tone to the ring of the phone.
Dec 05, 2008 | LG RUMOR Cellular Phone
LG Chocolate Ringer problem
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Mar 28, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Ringtones
Go into ring styles, and see if you can't select the ringer from there.
settings>ring styles> detail > calls, and hit change/select
Oct 02, 2007 | Motorola Mobility RAZR V3
Phone Doesn't Ring
If the phone has a dial tone, adjust the ringer loudness (this adjustment is on the bottom of some phones). Also check to see if there is a switch for turning off the ringer--and turn it on. In some cases, you can't connect more than five phones to a given line or they won't ring properly. If this is your situation, you may have to disconnect one or more phones, or at least turn their ringers off.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Motorola Mobility ROKR E6 Smartphone Logo
29 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
