FixYa.com
Tags:
Toshiba 50H82 50 in. Rear Projection Television
Hyper board location and removal (by 4 users)
posted by temellor on Mar 31, 2008
I am also having the same problem with a wavy picture on my 5 year old 50H82. I would like to be able to pull out the hyper board but I do not know where it is located when viewing from the back of the set. Is there any way you can give me the location or better yet a picture? I called the Toshiba service center in my area and they want $129 just to pick up the TV. I am not looking to invest alot of money into this set but I thought if I could bring the hyper board into the shop for a tech to test it would be a less expensive way to go and also the set is in my basement which makes removal of the entire set a hassle. Thanks for you help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by theairman, posted on Aug 14, 2008
I too was having similar symptoms. Even with the TV off we were getting white lines spiking from the bottom to the top of the screen. I purchased mine on 1/3/03. About 5.5 years seems to be the magic number with these Toshiba models. What is the residual value of this TV now?
Is it worth dumping another $ 400 to $ 600 into @ this age? I wonder what the donation value is to the Salvation Army?
Comment by Guest, posted on Jun 29, 2008
i've got the same problem as the rest of you have. we all bought the same p.o.s. toshiba tv. not the next time though
Comment by aseltenreich, posted on Jun 18, 2008
I have the same general problem where it now takes up to 10 minutes for the picture to become viewable. It's getting progressively worse.
Best Solution
posted on Apr 25, 2008
FixYa! (100)
Terryfic
Rank:Guru Guru
Rating: 87%, 1320 votes
Part # 23148024 PTS rebuild only.......core first.expensive....
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
Toshiba 50H82 50 in. Rear Projection...
Toshiba 50H82 Rear Projection...
I have a Toshiba 50H82 HDTV... Answer This...
screen replacement
i need to get a replacement... Answer This...
toshiba 50H82 projection tv
Please help, why is it when I... Answer This...
green screen toshiba 50H82
screen turned green on toshiba... Answer This...
PICTURE PROBLEM
we recently moved our tv, and... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
