Question about Kenmore 62622 Microwave Oven
Light Bulbs My bulbs burned out so I replaced them with 25W 120V bulbs and they work, but the controller button does nothing when a push it. The lights are always on. Thanks for your help! Martha
  • Kenmore Master
  • 9,174 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
SOURCE:
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
Whirlpool builtin microwave model mh6130xeq1. I replaced the 2 bulbs that were underneath the unit that shine on the oven, but the replacement bulbs do not work. They are 40w appliance bulbs; the same...
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when 1 of the light bulbs in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. A rather expensive repair for no lights. BUT BEFORE YOU DO THAT, get an ohmmeter and check your new light light bulbs and make sure they are really good. Also, if you can, get a bright flashlight and check the light bulb sockets in the microwave (unplug it first). Check for possible corrosion or signs of arcing on the center electrode of the socket. If that's the problem, you might be able to use a small screwdriver to scrape off the corrosion of the socket (make absolutely sure you have your microwave oven unplugged before you do that!).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 09, 2015 | Whirlpool Microwave Ovens
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
Operating interior light of bosch quantum speed microwave oven
Replacing the bulb is not really that tricky, and they only cost a few quid, so definitely worth doing:
1. unplug and take the cover off,
2. remove the two screws at the sides of the control panel, and move the panel out the way,
3. remove the metal plate covering the bulb area (5 screws),
4. squeeze and detach the springy fold of metal holding the bulb,
5. pull off the the bulb's electrical connections
6. unscrew and unhook the bulb, and replace!
My bulb was a 240V 25W T170 with right angled terminals.
Aug 18, 2013 | Microwave Ovens
Lights under microwave went out. Replaced the bulbs and bulbs work fine, however, now the "surface light button" will not work. Pushing the button will not turn off the lights. Lights continuously stay on...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Apr 26, 2010 | GE JVM1653 Microwave Oven
Bought a home with a Kenmore UC MV, Model # 721-62643200 Ser # 311KM02070. There were no light bulbs in it, so I bought two GE Indicator 25 T-7 bulbs, for microwave ovens. These bulbs are 25w 120v. Upon...
William E. Miller
[email protected]
Kenmore 721.62643200
Dec 25, 2009 | Kenmore Microwave Ovens
HOW DO YOU REPLACE THE LIGHT BULB IN A GE 1540 MICROWAVE?
1) unplug unit and remove microwave cover (phillips on 3 sides)
2) unscrew white funnel shaped plastic part near back of control panel
3) remove specialty bulb and disconnect leads
4) look for T170 bulb replacement (eBay has them) or roll your own 25W bulb solution
Nov 11, 2009 | GE JE1540 Microwave Oven
Replacement bulbs still do not work
Most electronic control boards have undersized circuit wires that can't handle a catastrophic lamp failure. The circuit trace will open like a fuse. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for open circuit trace.
4. Repair circuit trace...lights work again....
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Majic Chef cabinet mounted microwave oven model VM11B-8P
On the electronic control board, the circuit trace will open like a fuse if the light bulb power becomes shorted. If you or someone knows how to use a soldering iron, this can be repaired.
3. Remove circuit board from panel. Look on reverse side for a burned, open circuit trace.
4. Repair circuit trace everything should work again....
Jun 15, 2008 | KitchenAid KCMS145J Microwave Oven
Kenmore 62622 Microwave Oven Logo
85 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
