Question about Dometic RM2852 Refrigerator
Dometic RM2820, 2years old,use at camp on LP/12volt.When connected to power,ignitor and burner do not function.We suspect polarity was reversed in last hookup by unauthorized person. What may be the damage?
  • 668 Answers
The damage will be to complete power supply board . It will cost you very heavily if you need to change the power board . The power board inside the unit is damaged due to the wrong connection given by the person .
Hope this helps .
Posted on May 16, 2010
Our Dometic refridgerator in our 1992 camper
I would start there before replacing any parts. The circuit boards require 12volts to operate the refrigerator. If you have a good 12 volts and the LP tanks are full and the flame lights but the unit does not cool then you probably have a bad cooling unit. But start with the obvious issues first.
Sep 03, 2013 | Dometic RM2620 Refrigerator
10 year old DCS Oven does ignite. Oven ignitor glows but maybe not enough to trigger LP from being introduced?
just because the ignitor glows it doesn't mean it's good,it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,usually if the flame doesn't ignite in around 40 seconds the ignitor is bad.also check the burner tube,your model number doesn't come up so i don't know if you have one or two ignitors in this oven but i've found that when the ignitor starts to fail and the customer waits to long to have it looked at the ignitor burns a hole in the tube and then both the ignitor and tube has to be changed,hope this helps and good luck with your oven.
Jul 19, 2013 | DCS RGU-486GD-L Range 48", 6 Burner,...
Dm2652
if Lp system is ok replace board but check gas line for obstructions if no clicking noise bad board or ignitor
May 30, 2013 | Dometic DM2652 Americana Fridge...
Dometic rc1180 not cooling down on gas
clean all LP lines to ignitor if no clicking replace board
Oct 25, 2012 | Dometic Refrigerators
I replaced an ignition switch on my grill and again it is not functioning. It has new batteries but no clicking or igniting any of the spark ignitors. Is it still an ignition switch problem or could...
First off, is the battery installed in the proper position. The positive (+) end should be facing out. I that's not the problem, check the ground wire to make sure it is connected solidly and no rust in underneath it. Then check all the wires to each ignitor , making sure they are not damaged.
Jul 13, 2011 | Brinkmann Charmglow Stainless Steel LP...
When bake or broil button is pushed mode is not achieved. Can not set temperature. Timer and clock functions seem to work. Stove is sitting in my carport. Was pulled out of a house my daugher bought....
I would check your ignitor for power if you have no power to the ignitor when oven is turned on this would mean you need a control. If you have power to an amp draw test to see if it reaches the proper amp draw. To watch a free video on How to test this go to www.appliancehelponline.com/servicemanual.html
Mar 18, 2010 | Roper Kitchen Ranges
Furnace ignitor keeps breaking. Replaced it twice within the last month, for a total of 3 ignitors for one winter. I've been extra careful not to handle the graphite. Furnace was cleaned in the fall and...
Make sure that there is no water dripping off of the heat exchanger onto the ignitor. Reconnect all electrical connections on the circuit board and make sure the ground connections are clean. Test the polarity of the power coming in with a multimeter. Reverse polarity will fry ignitors. Make sure the furnace is on it's own breaker.
Mar 05, 2010 | Goodman Heating & Cooling
Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
May 26, 2009 | Dometic RM2652 Refrigerator
Whirlpool LP dryer will not light. model LGR7646EQ2.
the ceramic ignitor probably is broke. turnoff power and gas, then remove burner assembly ther are two screws holding it in. also loosen gas connecter .pull burner out an visibly check igniter you most likely will see the ceramic coil broken remove it and bring it and model # to a part house then reassemble burner
Jan 26, 2009 | Dryers
Dometic RM2852 Refrigerator Logo
70 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
