Question about Onkyo TX-8511 Receiver
My onkyo tx8211 stay on a stand by mode. I can
My onkyo tx8211 stay on a stand by mode. I can get it to work?
If it's anything like my Onkyo surround receiver, pressing any input selection will turn on unit.
Posted on May 16, 2010
Onkyo 390 CD player press power button and goes into stand by mode. Press stand by mode button nothing happens , how to fix?
Hi Joanne, the unit would have to be serviced, please follow this link to locate an authorized service center in your area, http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav, Thanks, JT
Nov 30, 2015 | Onkyo Audio Players & Recorders
How to prevent subwoofer from going to the stand by mode
According to customers on the Amazon website there is no override option to prevent it switching off.
Sep 28, 2014 | Onkyo SKW-204 Powered Subwoofer
Onkyo tx-ds989 goes to stand by mode just playing for 3 second ... rest every thing is ok I just hear a click sound (relay switch off) and it goes to stand by mode again switch it on .... same thing...
Check the speaker wiring on back that it is not shorting against one another, output ic's may have bad solder connections and should be checked carefully.
May 28, 2012 | Onkyo Audio Players & Recorders
Cd player stopped working
The problem is in the power supply sector of the board, usually caused by a bulging capacitor that needs to be replaced.
Mar 09, 2012 | Onkyo DX-C390 6-Disc CD Changer
Onkyo AVR TX-SR444 not powering up LCD not lit.Stand by LED lit only,on stand by mode. Thanks, Sorin
if STBY red light blind after power button pressed, AMP blown. you have to find large shorted transistors
Mar 22, 2011 | Onkyo Audio Players & Recorders
Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Aug 12, 2009 | Onkyo TX-8211 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Jan 27, 2008 | Onkyo TX-SR500 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
My Onkyo 7.1-Channel Receiver
Take out all the cables unplug from mains for an hour ,plug it back in with no cables connected ,turn volume to full if it turns off its faulty ,if it stays on turn volume to minimum,unplug from mains,connect all cables,turn back on.
Sep 23, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-8511 Receiver Logo
240 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
