Question about HP Compaq NX9600 17.0-inch WSXGA+ BrightView 377219-001 PC Notebook
HP nx9600 screen stays black when coming out of hibernation mode
When my HP nx9600 goes into hybernation mode and then starts back up the screen won't come back on. I have to do a hard reboot to get the screen to come back on
  • 2 more comments
  • loadsofspam May 20, 2010
    I did find my own solution, I did turn off the hibernation mode and so far that did the trick. I'll try uninstalling the ACPI using Windows 7
    I did find my own solution. I just disabled the hibernation mode in the power management. I will try to uinstall the ACPI
    I will try the uninstall of the ACPI. I did find an answer of sorts for myself. I just disabled the hibernation mode.
  • loadsofspam May 22, 2010
    So far so good, thanks for the help
    Novelist:
  • 83 Answers
There are several reasons behind this.. u can apply below setps to get it resolved.
There is one document on HP regarding this issue. they say that this is known issue with Windows xp and have provided below the solution on the same. check the belwo link for the same.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01723632
However i would also recommend the below stpes to perform.
To reinstall Power Management, take the following steps:
1. Click Start, Control Panel, Performance and Maintenance, and then System icon.
2. This opens the System properties window.
3. Select Hardware tab and click Device Manager.
4. Click "+" beside System devices.
5. Select ACPI Power Button.
6. Right-click the device and select Uninstall.
7. Restart the system.
Power Management will get installed automatically on restart.
You need to update the latest BIOS
== Try Resetting BIOS
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, from the File menu, Select "Restore Defaults" and then select "Save changes and Exit"
I hope this solution will work. Plz get back if this solution resolvs ur issue or not.
Dreamkam..
Posted on May 16, 2010
  • Kamlesh Ujgare
    Kamlesh Ujgare May 20, 2010
    Yes..but thats temporary soln..so wen u get tym apply these soln.it should resolve ur issue permanently...
    thanks..
My laptop doesnot come back from hybernation. I have xp on my Toshiba laptop.
Common problem with a lot of laptops.
I recommend you shut it down as opposed to let it hibernate or just turn off hibernation
Start... Control panel.... Power options... Hibernate ... uncheck the box "Enable Hibernate"
Jan 03, 2011 | Computers & Internet
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Wont come outof hibernation goes to a black screen even upon rest
RESTART IN SAFE MODE.
OR
REBOOT SYSTEM, BEFORE IT BOOTS PRESS
F6 UNTIL YOU HEAR THE BEEPING NOISE, THAN STOP AND SELECT SAFE MODE
THAN CONTROL PANEL AND SELECT POWER OPTIONS
POWER BUTTON OPTIONS
Mar 14, 2009 | Computers & Internet
MY LAPTOP SCREEN GOES OFF THEN THE SYSTEM GOES INTO HYBERNATION DURING MSN CHAT WITHOUT ME TOUCHING ANYTHING
FIRST TURN OFF HIBERNATION MODE, BAD BATTERIES CAN MAKE THE COMPUTER DO THIS AS WELL, USE THE SYSTEM WITHOUT THE BATTERY TO TROUBLESHOOT THE SYSTEM FROM THAT POINT. ADJUST YOUR DISPLAY SETTING FOR LAPTOP IN THE CONTROL PANEL OR THE DISPLAY SOFTWARE SUITE THAT CAME WITH THE SYSTEM
Aug 11, 2008 | HP Computers & Internet
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Random Hibernation
this sounds like power settings options.
what i can suggest now is that......................
go to the Power Options in the Control Panel and do the following.
  • first uncheck the hibernate option on the hibernate tab
  • use your computer and see if the problem re-appears, go to the control panel and on the power option, select Never to all options when using battery or ac power.
cheers...............
Oct 24, 2007 | Sony VAIO VGN-N130G/W Notebook
HP Compaq NX9600 17.0-inch WSXGA+ BrightView 377219-001 PC Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
