Question about Kenmore Elite Oasis 27052 Top Load Washer
Fl4 problem, kenmore elite won't spin or drain anymore.
Hi, i have a Kenmore Elite top load washer. It doesn't spin or drain anymore. the code fl4 comes up? do you have any suggestions on how i can fix the problem? thank you very much
  • 15,935 Answers
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Washer not spin
I have a Kenmore 60 sirce washer it drains put won't spin
Dec 07, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loader Washer Doesn't Drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washer
Try this first.
Washer won't drain or spin
Is the drain hose clogged, or the end of the drain hose
more than 96" (2.4
m) above the floor?
Is your voltage low?
Check electrical source or call electrician. Do not use an
extension cord.
Is the "SUD" routine active?
Cycle will complete once extra suds are removed.
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
120 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
