Question about Goodman GMS90703BXA Heater
Heater will start, gas on for a few minutes, then goes to cool air only. I have done the close down procedure a number of times. The unit is about two years old. Is it the thermostat?
    President:
  • 1,469 Answers
Hi, answer to your question is possible, a little bit long. You can use this link to fix the problem so fast. Just get into the link and get the problem solved,,
hometips.com/repair-fix/hot-water-heater-problems.html.
Hope it helps.
Take care.
Posted on May 16, 2010
Heater runs for 2-3 minutes then quits
Either the unit is over heating and being thermally shut down or the temp shutdown switch is shutting down prematurely.
Jan 01, 2016 | Heating & Cooling
Display says "CFH" but heatert wont fire up. Just makes a clicking sound
You don't have gas supplied to the heater. It sounds like you have a gas powered unit and the clicking you're hearing is the sparker sparking.
Jun 07, 2015 | Pool & Spa
I have a Hayward H100i, 100,000but spa heater. I recently had to replace the blower. Now the unit seems to get so hot that is shuts off every few minutes and stays off until it cools.
unfortunately you have damage the heat ex-changer with low p.h. either is block with green suit or the baffles are been damages and all the hot air goes fast look for bend pipes inside the heater will see the damge?
Dec 05, 2014 | Hayward 100kbtu Pool Or Spa Propane Gas...
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
RHFE-551A heater goes into lockout when starting from cold.
There are very few parts available for this unit. If all you have to do is wait for the unit to cool down and recycle the on/off button to start the heater, it may be one of the coils that open up the gas valve. To test if this is it, once the unit fails to start get your multimeter out and unplug the three coils on the gas valve and measure the Ohms across the tabs on the coils. You should get a reading between 1400 and 1700 across. If you get nothing, it is bad. The next thing to do is to remove the slide thermostat and clean it out using a Q-tip and some alcohol or one of those alcohol hand wipes. Lastly, inspect the unit for any bad connections and re-tighten the ground wires.
Dec 20, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Dryer flame starts for a few min then goes out
When it goes off will it restart immediately or do you need to allow some cool down time?
If cool down time is needed it's likely the coil kit which is part number 279834 for your model.
Other possibilities are air flow too slow causing a "lazy" flame which shuts off due to hitting safety thermostat sitting on top of the flame tunnel.
Aug 23, 2009 | Dryers
Temperature gauge past "H", air from heater comes out cold.
open thermostat or instrument voltage stabilizer.
Nov 25, 2008 | 2001 Subaru Forester
Goodman GMS90703BXA Heater Logo
20 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
