Question about Dell F3534 Touchpad
Left button isn't working - Dell F3534 Touchpad
    Problem Solver:
  • 17 Answers
If you can hear a click when pressing the button the mechanics may be OK. Unplug and replug the mouse in.
If USB, try mouse in a different connector.
Borrow a mouse and see if it works then.
If it is a wheel mouse (as opposed to optical) it may simply be full of dust and grit. Open it up and clean it out after disconnecting from the machine.
Posted on May 16, 2010
Samsung p510 left clicker isn't responsive. I am having to double tap the touchpad in the mean time. What is this part called on a laptop?
The left button, buy a can of compressed air attach straw and lift left button with fingernail gently, now give a few good blasts to clear out any dirt that might be obstructing the pad underneath the button, repeat if needed.
Apr 15, 2012 | Samsung N Computers & Internet
AOC A15X221 have picture no sound
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
My dell inspiron laptop's left click button isn't working as well as it use to, i think it maybe worn down, is there anyway i could get it replaced, and if so, where?
Simple solution with less cost is please use the external USB mouse.(Small size also avaible in market.) You are not mentioned the location where you are, Please locate the nearest Laptop service center for repair/replacement.
Try once with installing the Touch pad drivers.. .
Jun 28, 2011 | Dell Inspiron 1750 Laptop
The 4 black buttons in a column at the top left hand corner of the vci-100. The second one down from the top isn't sending data, and the button is kind of squiggly. I know this may just be normal wear...
The solution is likely replacement of the button switch portion. Be careful of applying too much pressure... often they have plastic hinges for the buttons and they can be broken by applying too much pressure in an attempt to get them to work.
Jun 22, 2011 | Vestax Vci 100 Midi Controller
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Okay so my right button isn't working properly i have to hold it down for a while for it to register the right click, I really need help, thank you
The only cause I can think of is a weak battery. If this is not the case, then the mouse could have a bad or dirty contact under the right button.
If you can scroll and the left button works well, I'd lean toward the dirty contacts.
Jun 03, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
The monitor isn`t working it has the letters E O 11 in top left corner
Hold down the 4 bottom buttons(recall,2 set digits,ready).While holding them down,press and release the ON/OFF button. Now release the other 4 buttons....the monitor should do some fast counting for 15 seconds and then display a 5 in the center area.Now press and release the ON/OFF button again and your screen should work!
Feb 16, 2011 | Concept2 2 Rowing Machine
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Logitech wireless mouse
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Nov 05, 2007 | Computers & Internet
Samsung SyncMaster 193V magicbright
hold the menu button down until the menu disapears again
Mar 11, 2007 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Computers & Internet Logo
200 people viewed this question
Alun Cox
