Question about E-Machines eMachines Desktop PC
Replace power supply, computer on, monitor no signal, help
Replace the power supply now my computer comes on but there is not signal to the monitor. before it replace power supply everything work except my computer would not stay on, now my computer comes on but gives not signal to monitor.
  • 64 Answers
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
Posted on May 16, 2010
My e machines home computer won't come out of.
Power save mode is just the message a monitor will display when there is no video signal from the computer to the monitor.
If the computer has no lights the problem is most likely the power supply and it will need to be replaced. Pretty easy to do, youtube it for tons of videos.
It also could be the motherboard is bad. I would start with the power supply first.
Dec 02, 2012 | Computers & Internet
Acer ASpire M1100 shows No Signal on monitor
Any time a monitor says "no signal" that message is originating from the monitor itself, and not from the computer. A monitor in a room by itself with no computer will say "no signal" for a brief time, if it is turned on. So, if you have tried other monitors also with no luck, then the problem is either the video adapter of the computer, or something that is keeping the computer from booting in the first place (power supply, hard drive, memory, motherboard). A power supply can be tested with an inexpensive tool. Everything else needs either a swap out with a known good stand-in, or else an expensive tool to know if it works.Does the fan come on when you turn the computer on? If so, maybe more likely to be the motherboard, hard disk, or memory. If not, more likely to be the power supply.
Feb 02, 2012 | Computers & Internet
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
No signal when power button turn on
Sounds like either the power supply unit's fan isnt functioning and the the uniy over heats and the computer then wouldnt boot up (to protect itself) or the processor is overheating. But rather seems like a power supply problem
Jul 06, 2009 | Acer AL1916W 19" LCD Monitor
Monitor made a popping sound and went blank. no computer or tv signal coming through.
Sounds like a Power Supply comcponent failure in the high voltage panel supply circuit.
Backlight power seems to be ok.
Can only suggest obtaining repair quotations vs. Replacement purchase?
Oct 02, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Flat screen monitor comes up with No Signal
If it goes to NO signal again, its not necessarily the whole Flat screen that is dead. Just replace the Video logic board with a known good one and it should work
Most monitors only have 2 or 3 boards
Logic board, Inverter, Power supply
or Logic video ,and a power supply board with an embedded inverter.
You have to open the monitor and replace.
Sep 13, 2008 | Computers & Internet
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Balance Monitor
Same exact thing has happened to me. We have determined that the monitor itself is good, but the DC adaptor is what went bad. Now I am on the hunt for the power adapter.
Sep 20, 2006 | Balance CM2017 17" Monitor
E-Machines eMachines Desktop PC Logo
147 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
