Question about ViewSonic N3751W 37 in. LCD Television
Help tv wont turn on. green blinking light
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
ViewSonic N3751W 37 in. LCD Television Logo
127 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
