Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Jazzy select. quick operating cutoffs locations,when i hook up the chagrer. the lever control blikks eight times and then quits cant find an opening or a short. i need a copy of the wireing schematic. .
  • thomas_h20 May 16, 2010
    iam a television technicionand iam capable.
  • 177 Answers
Hi. On some machines eight flashes is a fault code for a faulty motor. Usually means that the brushes have stuck or worn out. Use a multi-meter, and see if both motors have a circuit through them. Good luck. Neil.
Posted on Jun 01, 2010
I have a jazzy select 6 and when I turn it on it gives me eight flashes pauses and give me eight more flashes what the problem?
Hi the control system is faulty. ::::::: check power module & joystick module connections & wiring..cheers
May 21, 2017 | Select Health & Beauty
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Dec 03, 2015 | Pride Mobility Pride TSS300 Power Chair -...
Front hood wont open seems like cable has come off i cant try to get the front grill out as one screw is tightyd up from inside and its hard to get the screw out from inside from outside grill
Ive had this problem before. Get a metal coat hanger and make the wire long reach up underneath the car behind the grill and you will locate the lever that flips the bonnet. Wrap the hook of the metal coat hanger around the lever and give it quite a tug and it should open.
Sep 05, 2013 | 2006 Kia Picanto 1.1
Pride jazzy select turns on but when you try to move the battery light flashes 8 times then turns off.
Appear to be a problem with you control system. Check joystick module and power module connections. Look for frayed and damaged wiring.
Mar 24, 2013 | Pride Jazzy Select 6 Indoor Power...
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
2004 Mazda RX8 heater blowing cold air?
First thing to check: Does the temperature gauge in your car go up to normal quickly when starting out in the morning? If not, replace the thermostat in the engine. It is stuck open. . Then do this: Check to see if the cable actually moves a lever on a device that has hoses hooked up to it on your firewall in the engine compartment. Have an assistant help you by moving the control levers. If no control levers, the duct system is operated by vacuum and one of the doors that throttles the hot air into the passenger compartment has quit working. You'll have to check to see if that vacuum motor is operational. You'll need a manual to make the job easier. . Hopefully it is the first problem, as the second one is rather difficult to troubleshoot and get to (under the dash).
Nov 25, 2009 | Mazda RX-8 Cars & Trucks
Have jazzy select series need to know flashing code #9 purchased new batteries
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Jul 09, 2009 | Pride Mobility Products Jazzy Select
Pride Jazzy Select batteries not charging
If you use an automotive charger you have to charge each battery individually as they should be 12vdc hooked in series.
Clean contacts and assure yourself that each lead is charging properly. Jazzy has many different models so it impossible to know which you have. But there should be some info on the charger to tell you if your output is 24v or 2-12volt DC leads.
Jazzy has a web site and there is a member section where you can ask questions.
May 16, 2009 | Pride Mobility Products Jazzy Select
Hot air comes out at all times even when i turn on a/c
I think your cooling fan (elecric) isn't working when the a/c is on. If so, The a/c pressure climbs very high and pops open the emergency pressure release to save the system from damage.
Check your cooling fan and relays, or ect, engine collant temp sensor.
You may have to add freon too.
A/C Pressure Cutoff Switch
The A/C pressure cutoff switch is used to interrupt A/C compressor operation in the event of high system discharge pressures.
  • The A/C pressure cutoff switch is mounted on a Schrader valve-type fitting on the A/C compressor to condenser discharge line.
  • It is not necessary to discharge the refrigerant system to remove the A/C pressure cutoff switch.
  • A valve depressor, located inside the threaded end of the A/C pressure cutoff switch, presses on the Schrader valve stem.
  • This allows the A/C pressure cutoff switch to monitor the compressor discharge pressure.
  • When the compressor discharge pressure rises, the switch contacts open, disengaging the A/C compressor. When the pressure drops, the contacts close to allow operation of the A/C compressor. For specifications regarding operating pressure(s), refer to Section 412-00 .
The switch contains a second set of electrical contacts used for high-speed cooling fan control.
  • When the compressor discharge pressure rises, the contacts close and engage the high-speed fan control. When the pressure drops, the contacts open and the high speed fan control is disengaged. For additional information, refer to Section 303-03 .
Apr 24, 2009 | 2001 Mercury Grand Marquis
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
90 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
