Question about Keurig B50 Coffee Maker
Continually running/heating I have had my Keurig since Thanksgiving and really love it but I've recently began to have a problem. When my Keurig is between brewings it makes a continual heating sound as though it is having trouble keeping the water heated...I guess to sound highly technical it's like a swishing every 20 seconds or so. Any ideas would be appreciated.
  • Anonymous Apr 19, 2008
    I have had my unit for almost a year, and yesterday it begain to sound like it was heating approx. every 20 min/half-hour. I unplugged it and left it over night, but the problem persists. It still makes a fine cup of coffee, but we do have safety concerns.
  • Anonymous Mar 14, 2014
    keurig winding sound. doesn't heat water. display doesn't work. turns itself on.
    Scholar:
  • 79 Answers
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Posted on Mar 31, 2008
Recently mu Keurig started acting funny. When I first turn it on, instead of heating up, it just starts to fill my cup. Can't seem to get the "menu" up either! HELP
I watched a U Tube video, a 10 year explained how to clean the Keurig so it would work. Now all you have to do is go to Bed Bath & Beyond. Buy Clean Cup. It cost $7.99 It is a K-Cup put the pod in your Keurig run twice. Take the Clean Cup pod out, run twice with just water. Take a new thin paper clean to clean your needle.
When you close the lid so you make coffee. Surprise Open the top their is needle that becomes impacted with coffee grounds. Throw away the paper clip run a cup water and look at all the mess come out.
Sep 07, 2017 | Keurig Coffee Makers & Espresso Machines
Well my Keurig wasn't working as fast as it used to and this morning when I went to add water...I removed the cover and a zillion sugar ants came pouring out of it. Right from the hole where the water...
I HAVE THIS SAME PROBLEM WITH ANTS IN MY KEURIG. I've had ants in the past during the springtime and I've never had a problem with any other coffeemaker being infested with ants. I saw two ants actually crawling around underneath the blue brewing light while the machine was brewing plain water! I've de-scaled it with vinegar and have run water through it over and over and over again. There are STILL ants in it. It's currently outside my home and I have no other ants in the house. I called Keurig just to see if they have heard of this happening and they told me no and that it's an environmental problem. That's obviously a lie because all you have to do is Google Keurig and ants and you can read of other problems. I think I am probably going to throw the Keurig away . . .
Feb 19, 2011 | Keurig B60 Coffee Maker
We purchases a new Keurig coffee maker and tried to set it up for the first cup of coffee. the menu and add water prompts came on; however, it never heated the water. It is now continually flashing not...
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Keurig B50 Coffee Maker
My Keurig was running fine and recently I purchased a box of Timothy's coffee which seemed to have bubbled lids...since then my machine doesn't brew and entire cup of coffee and it shuts off when its...
I have the same problem. Timothy's seem to be the culprit. I hate to blame a specific k-cup, but I can run a cup of my wife's favorite (non-Timothy's) through right after I have the problem and they work fine - so that clearly points to the k-cup as the problem. Maybe they are more full of grounds or manufactured weaker...when I have the problem, I took apart a k-cup and the filter had broke, therefore all grounds were clogging water exit... I love the Timithy's coffee - best taste and strong, but maybe they aren't designed the best.
Nov 18, 2010 | Keurig B60 Coffee Maker
I have the Keuirg mini plus and i just opened it. It flashes red like it is heating and then just turns off. No brewing.
Same here. (I have the Mini Plus B31) Called Keurig and these are the steps they walked me through. Not sure which part actually fixed the problem, but it worked.
1. Turn off machine. Using a paperclip clean out the holes in the needles (3 in the top, one in the bottom of the k-cup holder).
2. If water is inside the heating core (assuming it is as nothing happened when you tried to brew), with the machine turned off, press and hold the brew button. After 5 seconds the pump will kick on and discharge the water. Make sure you have a cup in place to catch the water.
3. Dispose of that water.
4. Unplug the machine.
5. Wait 5 seconds.
6. Plug machine back in.
7. Turn on.
8. Run empty cycle without a k-cup and only use the minimum amount of water (6 oz).
9. Dispose of that water after it brews (hopefully).
If still nothing is happening, call Keurig.
10. Brew your coffee, tea, choco, etc.
Note: was told by Keurig rep that whenever you use hot chocolate, to run an empty rinse cycle afterwards before brewing another cup. This will help prevent any choco from going up inside the machine and possibily blocking the water flow.
Hope it works! Mine did after following these instructions. The rep also wanted me to measure the amount of water that came out afterwards. Not sure what the next step would be because my call got dropped, but the machine works. Sipping on a cup now...
Oct 16, 2010 | Keurig B60 Coffee Maker
Keurig problem.
Check to see if the gasket around the top "pointy thing" is damaged or missing. That just happened to mine.
Keurig will send you a replacement gasket free of charge. Just call them at 1-866-901-BREW (2739) with your model and serial numbers. The numbers are on the bottom of the machine.
Oct 30, 2008 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
1,308 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
