In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
There are 3 possibilities to charge the battery of the camera:
1. Connecting the Olympus' USB cable to camera and computer. 2. Connecting the wall charger to the camera with Olympus' USB cable. 3. Using a specific separate wall charger for LI-50B batteries.
Be sure to connect the cable well and if the orange LED does not light when trying to charge the battery using above points 1 and 2, there might want to exchange the Olympus' USB cable first to check what's wrong. (Cable model: CB-USB6). Another point is to check if the battery is seated well in the camera.
The charging cable is different from USB flash cable.
You can go through the booklet provided with the phone and it will show the diagrams of the cable and their part no.
The charging cable has the two pin plug on one end whereas the USB flash drive cable will have USB heads on both ends, one which goes in the phone and the other which goes in computerMake sure that you down load the software which comes in the CD (which came with your phone) on your computer.
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Yes you can,Connect your nuvi to a computer using a USB cable.The computer must be on for the nuvi to charge.A camera USB cable can be used to do this,or any USB cable that fits both the nuvi and USB port on the computer.
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Yes, you can use the USB cable to charge the battery. But you need to insert the cable into the computer USB port, no the USB HUB, and the computer is on, not in sleep mode.
