Question about Mitsubishi WS-55857 55" Rear Projection Television
I have the bowtie effect on my picture that cannot be fixed in the advanced menu. For awhile it had gone in and out but now it remains. Sometimes there appears to be angled lines that flash on and off too. Any thoughts on how to repair? - Thanks
    Problem Solver:
  • 12 Answers
This is a common problem with these sets and is usually the convergence IC chips. The soldering joints on them become loose over time as they heat and cool and eventually lose connection. This usually just requires the chips to be re soldered. If it is not fixed promptly, the IC chips then go bad. If you can give your TV a good WHACK! and the problem either goes away or comes back, the chips are probably just loose. A shop will charge about 250-300$ for this repair, or you can order a kit and do it yourself for about $100.
This is a link to a kit for your TV.
http://www.tvrepairkits.com/xcart/home.php?cat=2644
Posted on May 16, 2010
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
Rear Projection - Color convergence/bowtie effect
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 04, 2010 | RCA HD56W66 56" HDTV
RCA HD52W69D with a slight convergence & bowtie problem
Ur convergence it dead.If can't auto adjust must replaced.Tries Tv repair World.com,Tv repair kits.
Nov 04, 2009 | RCA HD52W59 HDTV Projection Television
I replaced the convergence board and ICs, but picture stil bowtie
Did you go into the convergence menu and allign the colors? Here's the link where i fixed mine... it's got the remote control button layout to adjust everything.
Jun 23, 2009 | Akai PT5598HD 55" Rear Projection...
Bowtie effect
convergance replace STKs
Mar 12, 2009 | Televison & Video
3d image/sinking effect
This is a convergence problem. Ther are either bad connections at the convergence ICs or the ICs are defective. If you can solder, you can repair this yourself. Try resoldering the pins on the ICs first. If that fails to resolve the problem, replace the ICs. These ICs are large, black and attached to a heat sink. They should be marked STKxxx. Figure on $20 for each one. There will be 2 of them.
Keep us posted.
Dan
Jun 02, 2008 | RCA D52W19 52" Rear Projection Television
N3230-no pictures appearing on LCD
i also encountered such problem.. try to open and check the connections from the lcd, this maybe loosen.
Aug 30, 2007 | Nokia 3230 Cellular Phone
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
366 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
