Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Have lever to raise 3 point hitch on joh deere
Have lever to raise 3 point hitch on john deere 2010 but it seems to be missing something so it does not lift? its a 63 year model.
4 Suggested Answers
  • 143 Answers
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
IF the rest of the hydraulic system has normal pressure, then the control valve for the 3 point may be faulty, or ; the hydraulic cylinder that raises/lowers the 3 point arms has failed (the sealing ring on the internal ring has torn)
Posted on Jun 20, 2009
In the worst scenario, the follower, or the piece that senses load on the control shaft , may have broken. Several causes could be the culprit, but happened on my 2520 . Fix requires total disassembly of final drive and differential to remove control arm and repair the follower. Good luck.
Posted on Jun 27, 2012
wadingriver
  • 2069 Answers
SOURCE: JOHN DEERE 4300 3 POINT HITCH PROBLEMS, WILL GO UP AND DOWN AFTER YOU START IT. AFTER USING 3 POINT HITCH UP AND DOWN, THE DOWN MOTION WILL SLOW DOWN DRAMATICALLY TO THE POINT WERE IT WONT GO DOWN AT
A reversable pump operates the Hitch. sounds like a bad valve in that direction. If Fluid level was low, it would be a problem in both directions.
Posted on Sep 12, 2012
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Deere 5525 control stick is difficult to pull back
Are you talking about the three point hitch lever? Does it have a cable going to the three point hitch spool valve? If so, try spraying penitrating oil in the cable at both ends.
Jan 02, 2015 | Garden
How do I get the rocker arms to move? I want to but a 3 point hitch on my 60 but i do know how to get hte rocker arms to move. Are there valves that need to be adjusted?
You need to put your hydraulic pump in gear and the lever that runs the hydraulic outlets will run your rockshaft it might not go down if there is no load on the 3-point.
Jan 14, 2010 | John Deere 3-point Hitch Kit A,b,g,50,60...
I need to know where to add hydraulic fluid in a John Deere 2010
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Nov 04, 2009 | John Deere 4000 201000-> Gas & Diesel...
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
107 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
