Question about Fujitsu LifeBook E7010 Notebook
My fujitsu lifebook e7010 doesnt always turn on properly
Hi i recently brought a fujitsu siemens e7010 and i find it doesnt always show a picture on the screen but always powers on and cd drive spins when cd is in,i know it works as sometimes it turns on then crashes and the picture wobbles but other times i have to hold it on its side to get it to display the picture does anyone know what could be wrong with it many thanks
  • 2 more comments
  • dansmith2008 Mar 31, 2008
    it only displays a picture on an external when there is a picture on the internal lcd and the picture is perfect for the time its on for ,could the problem be because of the ram as when it doesnt turn on i changed the ram around it power up with a display,so is it worth getting some more ram to see if that works?
    thanks
    hi there is no beep at all as there isnt a internal speaker,also when it did boot and show a displayi got into bios and set the display to external and internal(simaltanous) and there is only a display on the external when there is on the internal ?
    mewms_14904,hi i went into bios and checked and it says video memory 32mb but you cant limit the amount you use on this?
  • mamatt May 10, 2008
    hi,i want to know why type of hard drive for 7010?i have tried both SATA and IDE type but still dosnt fit!pls help,regards
This type of laptop has problems with its video chip. We have a couple of these and they all have to go to support and always the solution has been the change of the motherboard
Posted on Jul 15, 2008
  • 37 Answers
Try using the function keys (FN + number) to try the switch forom an internal screen to an external and see if that makes a difference to the picture.
Also when you turn the computer on do you hear any system beeps (apart from the single beep at startup)?
Posted on Mar 31, 2008
    Genius:
  • 1,027 Answers
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
  • Mark Williams
    Mark Williams Mar 31, 2008
    It could be either a shadow ram for video problem or the video card on the mother board. I am not familiar with the life book. I had a similar problem on a dell and after I reseated the display adapter to the mother board and insured a proper ground there was no further problem. I believe the video adapter is on the mother board. since the external only works when internal is working this would indicate adapter problem. If the bios can be entered check the amount of video ram has been allocated. Limit it to lowest setting and see if this helps.
I have a fujitsu siemens lifebook E7010 laptop and the problem is this : When I switch on power the system goes ON but with a black screen and the small LCD is showing the start logos CD player is working...
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 22, 2011 | Fujitsu LifeBook E7010 Notebook
I have a Fujitsu Siemens Lifebook E7010, and smotimes it work great, but somtimes it will not start, there ar just 1 long beep and 2 short beep tones. pleas help
check for updates on fujitsu web.. it seems you have to flash the bios.. (when it beeps in most cases there is hardware problem... proc, ram, hard drive, or even mother board... check with manufacture if he had post some of the new updates for your laptop
Dec 02, 2009 | Fujitsu LifeBook E7010 Notebook
BLUE SCREEN STOP ERROR AND NO HARD DRIVE SHOWING
Sorry, but there's no real way to troubleshoot this without actually having the device. The problem you describe could be anything from a simple corrupted system32 driver or MBR (master boot record), to a hardware failure. The simplest thing you could try is to boot from your OS installation CD/DVD, reinstall the OS, and re-install your applications. Next would be to re-format the boot drive and restore your data from your most recent backup. Sorry I don't have better news for you.
Aug 16, 2009 | Fujitsu Siemens LIFEBOOK S7010D...
My cd/dvd drive on my Fujitsu Siemens laptop doesnt work
Right click on my computer icon then click on property then ->hardware ->device manager
then check there is any cd/ dvd drive showing in list.
If you can see your cd /dvd driver then uninstall it.
then restart computer.
But if you cant seen then you need to refix your cd dvd rom.
For that pull your cd drive from laptop but make sure there is 1 lock system near rom just press that lock and pull drive then refix it.
Aug 08, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Thanks
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
Keeps freezing during installation of xp
Ok, lets start from scratch.
If you can, connect a different CD/DVD drive and change your Boot Priority to boot from here first.
Insert your XP disc, and using the CD's settings, delete all partitions and reformat the drive (NTFS). Start the installation and see what happens.
If you have already done this, or it doesn't work. Check how scratched the CD is. As long as it's not a manufacturer's revovery disc, you could ask someone if you could borrow their XP installation disc.
A good way to get rid of minor scratches on your CD's, is to spray them lightly with furniture polish (with beeswax). Leave for a minute, then using a very clean dust cloth, gently clean the cd from the middle to the outside. N.B. never clean the cd in a circle motion, i.e rubbing.
Hope this works for you.
Tim
Dec 08, 2008 | Fujitsu Siemens LifeBook S7010 Notebook
LIFEBOOK E7010
3 beeps is generally a video card problem. Unsure if your laptop has separate video or if it is imbedded on the board, first make sure ram is fully seated in socket
Aug 27, 2008 | Fujitsu LifeBook E7010 Notebook
Fujitsu siemens 8830
check to see if lid switch is functioning correctly if possible.
if **thing seen,** change ,inverter board needs replacing.
you've tried changing moniter so it isnt cable connections internal or external.
you're **t hearing any beeps so it isnt video,mem or hd.
Mar 01, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu LifeBook E7010 Notebook Logo
1,201 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
