Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tub stopped draining /no spin cycle. - Kenmore 3.8 cu. ft. HE3 Front Load Washer
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machinetub stopped draining /no spin cycle. - 2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Tub filled with water, Lr code
To pump out the excess tub water while failing to complete spin cycle;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
If I could ask you to do a little troubleshooting;
It sounds like the wash/agitate cycle completes and you enter into the spin cycle of the selected wash cycle is that correct. When the wash cycle fails does the Cycle Status LED indicate that the washer is in the Spin cycle?
With a empty wash basket no wash load in the basket and you start a Spin Only cycle will the Spin Only cycle complete?
If the washer will start the cycle do you hear and loud Spin Only cycle noise such as metal against metal grinding noise?
With the washer off and no clothes in the wash basket can you open the lid then Spin the wash basket as fast as you can in the CCW direction the only direction. The wash basket should spin CCW several rotations and coast down to a smooth stop dose it?
I’m checking for Outer Tub increased bearing resistance…..Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The water will not drain. The tub starts
The pump is clogged. The only way to fix this is to clamp off the hose to the tub and remove the hose from the pump and remove what ever clogged the pump. Expect to get a little wet.
Mar 04, 2010 | GE WBSR3140DW Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Hoover AAA140 Front Load Washer
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
144 people viewed this question
fordexpert
Mike Squire
Robert Rankin
