Question about Waterway Spa Pump & Hot Tub Pump 1.5" Plumbing C15230ss
High pitched sound, water still circulating. 3hp motor, part# 7-187694-01
    Top Expert:
  • Waterway Master
  • 4,292 Answers
Bad motor bearings replace whole pump
Posted on May 01, 2016
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Hot watertank puts out high pitch sound
It is probably the water passing through some restriction such as a valve or maybe a T or 90. If this is correct changing the water flow will change the pitch and it will be absent when there is no water flow.
If that doesn't change or eliminate the high pitch sound I do not have a clue.
Jan 09, 2014 | American Standard Water Heaters
Hello I have a Grundfos circulating pump #UP1542F on my system. It recently started making this high pitched whistling sound for about one minute than quits. It seems to only do it on start up / when
I do not know your system but It sounds like a restriction forming in the system. It may be calcium deposits or a valve not closing properly.
Nov 22, 2013 | Plumbing
Intertherm furnace model m3rl060abw blower makes high pitched whine when running. why? how can i fix it?
not familiar with that specific model, but if it's high pitched, it is likely the induced air blower causing it. sometimes it is possible to disassemble the motor and clean and lubricate it, but the repair that most service personell will do is to replace the motor. often it comes as an assembly which includes the motor and fan.it's the easiest, longest lasting, and quickest solution.
it is possible that it is the circulating blower with a seized bearing causing the whine. if so, the bearings (and shaft) can be replaced.
Jan 27, 2013 | Heating & Cooling
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
High pitched noise
It sounds like you may have a bearing problem. The motor bearing eventually gets damaged by the water vapor that is drawn in by the fan. This will cause a high pitch squeel from the motor. It is possible to replace the bearing, but it should be addressed by a professional techician.
Jan 27, 2008 | Hoover F5886-900 Steam Vacuum
Waterway Spa Pump & Hot Tub Pump 1.5" Plumbing C15230ss Logo
333 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
