Question about Faema FA60081
Faema 91 Diplomat giving error (E2 code) message no water to boiler, and the water is full. Any suggestions and I'm looking for a tech. manual. Thx Gene
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Faema S-87 Spouts copious amounts of water from the top
There could be one of 2 things happening :
1. Problem with auto level.
2. Most likely the inlet valve has a small leak.
Posted on Feb 26, 2009
EsWorld
  • 1618 Answers
SOURCE: Older Faema double head. Power light on, but
It is on the right side of the machine behind the grouphead if you remove the top panel you will see te box with the red switch sticking out. MAKE SURE THERE IS WATER IN THE MACHINE FIRST!!!!!! Do not trust the sight glass, if the level probe is in there, turn machine to 1 then disconnect the electrical connector on the side of the sight glass, the pump should kick in and water will flow in the boiler, if the level does not increase in the glass, then the machine turned itself off because the element got too hot from lack of water. The hole for the sight glass is blocked.
Posted on Jul 31, 2009
SOURCE: i have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Posted on Sep 05, 2012
Testimonial: "yes i had a coffee machine mechanic look at the machine about 5 to 6 mnths ago and i have found 2 no of the restrictors missing so just waiting on new ones to put in ,so hopefully it fixes the problem . some people just dont no what they are doing i think dave "
We have a Faema E92 Elite, 3 head. The display keeps giving an error code: Boiler overpressure E1. Already replaced the heating element (the gasket as well). How do we get rid off the error message?
You have one of two things going on here, the boiler is really over a safe pressure (very dangerous condition if error is for real) or the pressure sensor is malfunctioning. For safety sake I would have a professional look into this, a boiler explosion is a very dangerous.
Nov 29, 2016 | Washing Machines
Faema E92 error codes E51 and 58 What to check?
Google this question and then post your answer as a comment to update others as well.
Nov 23, 2014 | Faema Coffee Makers & Espresso Machines
The hot water doesnt work on my boiler
The heater must give you an error code or warning light, first locate this, then look it on the manual, otherwise call the boilers technician.
Oct 12, 2014 | Water Heaters
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
Trip switches of the boilers trip constantly on my faema machine. how can I fix it?
The element trip switches will go if the machine does not get water fast enough if they are not immersed in water, so to protect the element form overheating it will trip. Is there a sight glass to see the water level, I do not know what model Faema you have but most of the Due's have a sight glass on the left side front panel. Do you have a water filter and or softener, is that restricting the flow and need to be replaced, did the new ones if recently replaced get flushed before install, or maybe the water inlet tube where it connects to the boiler is blocked, has the technician checked and or cleaned that fitting? Can you use the manual fill to see haw fast water is getting into the boiler?
Mar 20, 2013 | Faema Coffee Makers & Espresso Machines
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
I have a Faema X2 Grand Italia C/10 NF and looking for descriptions of error codes (specifically #055). Is there a manual that gives such information?
ERROR 055 IS KTY PLUGS TO THE GROUP IN MY MANUAL,I'M A TECH AND THIS IS WHAT THE DESCRIPTION SAYS IN THE X2 TECH MANUAL... under possible causes it says either KTY disconnected or Malfunctioning card..solution is to open the machine CHECK CABLING/REPLACE KTY/REPLACE THE CARD.. hope this helps!!
May 09, 2012 | Faema Coffee Makers & Espresso Machines
Error code e2 on Rheem tankless water heater
e2 is not shown among common error codes:
Error e2 might be: Brownout condition or too low of voltage to thermostat. Double check wiring and check for 24 vac between R and C. E2 will clear 15 sec after proper voltage is restored.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat and typical generic manuals and common error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Model number and serial number are required for Rheem contact, and then they tell you what error code means without saying how to fix it, and then tell you to call service technician.
Tankless water heater manuals each say to have qualified technician perform yearly service. Most causes for common error codes are covered by yearly service.
Yearly service is fairly standard in the HVAC and water heater industry with advancement of high-tech 'energy' saving appliances. Of course all costs are energy, and the service call probably costs more that the 'energy' saved by energy-saving appliance. But with high tech stuff like tankless, it is good to have a reliable service guy who knows your machine.
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Jul 27, 2011 | Rheem Tankless Hot Water Heater...
Espresso machine problems
You may want to have a close look at the seats. There may have been irregular wear on one or more causing the leak. Try and make sure each one is back in its original location.
http://www.faema.com/eng/contatti_rete.asp
Found a manual for you (closest match) It's only for a Faema Family. Well, what the heck, it's free!
http://picasaweb.google.com/Grendelpics/FaemaFamily
Hope you come right, cheers.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
404 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
pawnpower
richie46
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
