Question about NexxTech EDP3110
Disk of the dvd systmme won't open and close
Disk of the dvd system won't open and close
Why won't my Gateway PC DVD drive close?
Are all the Windows and Gateway updates and Hotfixes in? Look for a DVD rom fix on the Gateway website support. If there is no disk in the drive and it opens, you may want to replace it. You can try a work-around, I have no idea if it will solve the problem, but at boot open the BIOS, go to Boot sequence, Change HDD to boot first. DVD/CDrom 2nd or 3rd.
Dec 26, 2012 | Gateway Computers & Internet
Wont play game disc
What disc are you putting in?
Mar 19, 2008 | Microsoft Xbox 360 Console
Computer won't run disk
If this is a cd/dvd drive you are referring to
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Nov 03, 2012 | Computers & Internet
DVD Tray Will Not Come Out
Download updated software for free on Panasonic Website then take a Paper Clip or other small object and insert it in the small hole in front of the machine and manually open the Disk tray. The Updates should take care of the Problem !
Oct 13, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD player is broken and won't open and I have a disc stuck in there
you have 3 alternatives for open:
1) with the button eject or close/open
2) remote control. button open/close or eject
3) with small knife pull out the carrousel for to bring the disk, with carefully.unppluged the power cord.
otherwise you must go to the repair shop TV for fix it
God bless you
Jul 21, 2012 | Philips Magnavox MDV453 DVD Player
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
Nov 01, 2008 | Panasonic SC-HT740 System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
NexxTech EDP3110 Logo
Top NexxTech Televison & Video Experts
jasbo
jasbo
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
