Question about Xerox Phaser 8560MFP Laser Printer
I have a xerox phaser 8560MFP/D. I was told by an independent xerox certified repair station that I should be using Xerox-supplied only toner in my machine, else I will have problems. I do not wish to have problems, but xerox supplied toner is about double the price of other brands of toner. What kind of problems (and how many) have you seen with these solid toner stick phaser printers, as a consequence of using non-Xerox toner sticks? What kinds of problems, and with what frequency, should I experience with my printer as a result of using non-Xerox toner sticks?
  • Gary Christoph May 16, 2010
    Your responder did not read my question carefully. So I sent follow-up question.
    You say in your reply: "The regular maintenance for the unit is a good routine to make and keep it working in shape even when you;re not using the same brand of product due to budget or the difference of prices." I am not sure what you mean by "regular maintenance"? I do not have a maintenance contract. Too expensive. What is the maintenance schedule for this machine?
    Please read my questions carefully. You did not answer them all. How do I clean the machine?
    I consider myself technically adept. While I do not have a Ph.D. in rocket science, I do have a Ph.D. in nuclear science, and spent 15 years at Los Alamos as an engineer, first scattering neutrons and then as the CISO. So please give me information I crave. I do not like this game of 20 questions.
  • 6,487 Answers
Actually you can use third party toner on this unit or on any printer brand, manufacturer will always say that to a client that you will have problem in the future if you wont be using a genuine toner from them for marketing purpose of coarse. With my experience for different brands of printer you wont really be having issue using third party toner if you use it properly and check it regularly.
Posted on May 16, 2010
    So what should I believe? I was advised to go to this particular independent repair station by FixYa question two months ago. Understand that they will "say" 'you will have problems if you use non-Xerox toner sticks', but should they push xerox toner as part of their contract with Xerox? However, it was not the manufacturer, but the independent repair station in Frederick, MD that said this.
    As a measure of your experience with these machines, how many phasers have you dealt with in last few years? What are the most common problems you are faced with? What kind of things should I be watching for? Do you (or did you) have xerox certification to work on these machines?
    What do you mean by "use it properly and check it regularly."? How frequently should I be checking it? What should I check? Understand "properly" to mean 'insert toner stick in proper slot and make sure it is all the way down to feed', but what else is there to check?
    I am also interested in "proper" cleaning of the machine. I suspect that a flake of toner covered a sensor somewhere, and that resulted in an "out of [something]" message, but that went away. Not sure what I need to do to clean the machine "properly", what to look for, how to protect drum (I am told that direct sunlight can harm it), etc.?
  • Mark Gil
    Mark Gil May 16, 2010
    Here at Fixya we don;t have any contract with any manufacturer and we are a independent tech support site, Yes here we usually inform client to take it and use a genuine parts, accessories since that is really the best way to maintain and also to make sure that the accessories that client will be using is 100% compatible with the unit.
    I myself handled several unit like this and in our office we also use a third party toner , but for warranty purpose just in case the machine encounter problem the manufacturer will not tell us that the problem is due to the used of third party product for the unit.
What is Xerox Phaser 8560mfp fault code 00,006.74?
Hi Anonymous,
You need to contact your the www.xerox.com website.
Regards.
Jul 28, 2014 | Xerox Phaser 8560MFP Laser Printer
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
How much is the Xerox Phaser 8560MFP/D Laser Printer?
Here is a link to find out. Compare prices thanks for using FixYa! Click Here John
Feb 22, 2011 | Xerox Phaser 8560MFP Laser Printer
Hi can you tell me if the xerox phaser 8560mfp prints borderless please. Many thanks
No it doesn't. It is a shame because theoretically it is capable but it would require firmware/driver alteration which Xerox are unlikely to do.
Dec 20, 2010 | Xerox Phaser 8560MFP/N Printer
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
Is it possible to reset xerox phaser 6110mfp imaging units
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Mar 02, 2010 | Xerox Phaser 6110 Laser Printer
Printing Black & White
sure..but you need to set that in the settings of the documents printing under default(use greyscale).
Try this link for more Printer Resources
Aug 19, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
95 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
