Question about HP Pavilion m8120n PC Desktop
Computer was moved and now I have no sound
How can I troubleshoot for sound on my HP m8120n computer?
  • drallim May 16, 2010
    If your speakers are the amplified variety, the speaker plug should go into the 'line out' jack. Many systems don't offer direct amplified output. If still nothing, click on the speaker icon in the lower right corner, then pick 'adjust volume'. Look at the left side for 'master volume'--make sure the volume is turned up and not muted. Hope this helps!
  • HP Master
  • 4,737 Answers
Firstly check whether the sound driver is installed or not. Secondly, make sure that you haven't turned on the Mute (You will see red X mark on the sound icon). Thirdly, Check the output connector (Audio Jack). Forth, try your speaker to another system to see if it's working or not. If you follow all these steps and you still get no sound, then the problem is with the sound card. But in your case, I hope these will definitely fix your problem. Good luck
Posted on May 16, 2010
How do I open dvd tray on hp m8120n?
On all CD/DVD look for a tiny hole on the front tray.. use a paper clip ... insert the paper clip in the little hole... do it gently .. it will open the tray.. ALL CD/DVD have the little hole.. so look for it.. remember the hole is as little as a paper clip .. like a pin head small...
May 18, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
Getting 2 short beeps and 1 long beep – black screen. gave a quick message once – “could not initialize video card”
Your computer has memory problems. First checkvideo. If video is working, you'll see an error message. If not, you have aparity error in your first 64K of memory. First check your SIMM's. Reseat themand reboot. If this doesn't do it, the memory chips may be bad. You can try switchingthe first and second banks memory chips. First banks are the memory banks thatyour CPU finds its first 64K of base memory in. You'll need to consult yourmanual to see which bank is first. If all your memory tests good, you probablyneed to buy another motherboard.
Clean the ram and the ram slot .then fit it again.
http://www.ehow.com/how_895_install-ram.html
Hope it will help you.
Dec 23, 2010 | HP Pavilion m8120n PC Desktop
Want to upgrade memory but how do i access the mobo to add the new chips?
Open the access panelUse the following steps to open the case: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a noncarpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
NOTE: If you need product model specific graphics and instructions for opening the PC, search for a support article that specifically pertains to your computer. In the Search field (or Questions or keywords field) at the top of this page, type your computer model number, a space, and the words "opening the case."
  1. Turn off the computer and unplug all cables, except for power, and write down each cable location.
  2. Unplug the power cable and press the Power button.
  3. If possible, move the computer to a clear, flat, stable work surface over an uncarpeted floor.
  4. Remove the panel retaining screws.
  5. Figure 2: Screw locations (your model might look different)c01054110.jpg
  6. Slide off the panel to expose the inside of the computer.
  7. Figure 3: Panel removal (your model might look different)c00309906.gif
  8. If opening the case is difficult, search for a support article that specifically pertains to your computer. In the Search field (or Questions or keywords field) at the top of this page, type your computer model number , a space, and the words "opening the case ."
Jun 07, 2010 | HP Pavilion m8120n PC Desktop
Hp media center pc have sound but picture is just static
try to play the file with other palyer, install or search codec for your video, may be your player doesn't support or doesn't have the codec for the video file
May 13, 2010 | HP Pavilion m8120n PC Desktop
Wireless Keyboard stopped working
Try unplugging the receiver unti for 5 seconds, then replug it in. If this does not work you should try reinstalling the wireless system drivers. Hope this helps.
Dec 21, 2008 | HP Pavilion m8120n PC Desktop
Replacing power supply HP M8120N
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | HP Pavilion m8120n PC Desktop
HP Deskjet 3820 states system error
try disconnecting from computer, and run the test page from the panel..then, reconnect to computer and see if it repeats..sounds like the operating system may have lost the printer drivers..
Mar 07, 2008 | HP DeskJet 3820 InkJet Printer
HP Pavilion m8120n  PC Desktop Logo
69 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
