Question about Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
I have a Dyson DC04 which is making a strong burning smell within a few seconds of switching on. Is this likely to be the motor and if so can it be replaced?
    Brigadier General:
  • 4,088 Answers
More likely it is the beater brush which is jammed and not turning. Turn the machine over and remove the bottom plate. Unhook the drive belt, then try to turn the beater brush--it is likely bound up with string, thread, and hair. Try turning the machine on once--if the motor spins and makes vacuum, it is probably ok. Remove the brush assembly and clean it of debris. Clean the end bearings with a Q tip and WD40 oil, then wipe clean with another Q tip. Oil the bearings with 3-1 or other light oil. Check the belt for a badly burned area--replace if necessary. Slide the new belt over the brush and motor shaft, then drop the brush with bearings into the case, and check rotation. If ok, replace the plate and test on your floor. Hope this helps!
Posted on May 16, 2010
My Dyson dc14 vacuum is making flapping noise and loosing power, strong burning smell
If the air flow is blocked, then yes you will get overheating of the motor and a funny smell. One approach is to remove the part closest to the motor, and if the motor then runs okay, the blockage must be downstream. Perhaps there is an online manual that explains how it comes apart? Another thought is that the bearings might be going bad. Might be worth taking this vacuum to a repair man.
Aug 23, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
How to clean out dc27?
Hi there, it's Jack at Dyson.
If your DC27 seems to be making a burning smell in use, we would strongly advise against continuing to use your machine until we can inspect it and carry out a repair if needed.
Please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can take some further details. We can also confirm if your machine is within our 5-year parts and labour guarantee period.
Aug 19, 2014 | Dyson Vacuums
Dyson main switch
Repairing/removing the cable/switch on a Dyson DC04
http://paulroberts69.wordpress.com/2008/01/01/repairingremoving-the-cableswitch-on-a-dyson-dc04-or-similar/
Aug 13, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson dc04 my dyson dc04 wont turn on at all, it was working yesturday and now its just not switching on please can anyone help?
Follow the power from the plug to the switch through the vacuum until you reach the motor. Somewhere along the path you will likely find the problem. The most common problem is the cord or switch.
Mar 05, 2014 | Vacuums
Dc25 burning smell from motor
I'm sorry to hear you're having difficulty with your DC25. If the machine is making a burning smell, please don't continue to use it. I'd strongly encourage you to get in touch with us directly - our experts will be happy to confirm if we're able to help under the terms of the 5-year guarantee which covers all of our upright and cylinder vacuums.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have your machine to hand when you call so our experts can take you through a few quick troubleshooting checks.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 23, 2013 | Dyson DC25 All Floors Bagless Upright...
Smelly Dyson DC04
Hi Philip,
I'm sorry to hear you're having difficulties with your DC04. If the machine's making an unusual smell, we'd advise against running it again. I'd encourage you to get in touch with us directly so we can help resolve this.
You can call us on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Mar 10, 2012 | Dyson DC04 HEPA Bagless Upright Cyclonic...
The vaccum dyson 04 has a smell of burning
well there are a few versions of the dc04 what i would do first is clean out the filter and let it dry out completely for 24 hours. then i would turn the vacuum upside down and look at the roller brush. if there is a lot of hair or debris it would cause a burning smell. so clean all of that out. after that the only other thing that it could possibly be would be the belt or the clutch. you know you have a clutch if you can turn the roller on and off for bare floor and carpets. if the roller is continuously rotating then i would check the tension of the belt and for any rubber shavings. if its really loose or you do see shavings then yes you need to replace it. now if you do have a clutched system you will need to take it in and have your clutch replaced. the clutch and labor cost about $100
Sep 02, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson animal stopped working and produced a strong smell as if something had burnt out.What could it be and could it be repaired?
hi.
a strong burning smell would suggest an electrical burnout of some kind. could be wiring, switch or motor.
new motors are available for around £35 on ebay. switches are available as well. wire is readily available.
the machine would have to be stripped to find where the problem is (and the cause) and to make sure that there is no heat damage to the casing
it is not a difficult job to do, but i would leave it to a qualified electrician due to the mains electricity.
i have no idea what the electrician would charge in your area.
hope this helps
Apr 03, 2011 | Dyson DC29 Animal Vacuum
Dc04 does not power up!
I need a directional manual for dyson animal
Sep 20, 2009 | Vacuums
Dyson
Hi.
Check mains lead where it enters machine very common for internal fracture.
To prove this try waggling lead with machine switched on if it starts & stops this is the fault.
http://dc07.atspace.com/
Chris..
Dec 23, 2007 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum Logo
581 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
