Question about Canon imageRUNNER C3220 Color Copier
Error 012 in canon 6085
I find a error in canon 6085 . I also replaced feeder motar but i found result no please tell me what i do
  • 59 Answers
Hi dear uyou have problem in the drum drive motor not in the feeder motor, coz E012 After the drum motor drive signal has been generated, clock pulses are not generated within 2 sec thays mean yours drum motor is not moving may be the faulty motor or may be the power supply for the motor.
thanks
Posted on May 16, 2010
ERROR MESAGE: 39 012 40:124372
There is a failure with the Documents Feeder or ADF. There really aren't many parts sold separately for that unit, it would just need to be replaced, the part number is 004K07270.
http://www.iteminconline.com/itemdesc.asp?ic=004K07270-R&eq=&Tp=
Aug 26, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
E000732-0001 canon ir
Error Codes ecblank.gif ecblank.gif ecblank.gif Problem : ecblank.gif E000732 - 0001 Found cable from Machine to Reader becomes loose in reader housing due to Doc Feeder cable catching as the feeder is raised. ecblank.gif ecblank.gif ecblank.gif Sub-Assembly : ecblank.gif ecblank.gif ecblank.gif ecblank.gif Cause : ecblank.gif ecblank.gif ecblank.gif ecblank.gif Solution : ecblank.gif Replace cable (FH7 7167 000) dress Doc feeder cable away from plug by putting a twist in the doc cable before plugging into reader
May 13, 2014 | Xerox Office Equipment & Supplies
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
CANON 6085 PROBLEMS e214
error code E214 6085 machine problem solve pls
Apr 04, 2012 | Canon NP 6085 Copier
E012 code
check feeder moter
Nov 14, 2009 | Canon NP 6085 Copier
Alarm is ringing ##356 is dispayed on screen also on screen is the words check printer press ok
That error is a sheet feeder error, the paper feeder is not moving properly. Any time I've found this problem, I've found broken gear studs and the feeder assembly needs to be replaced. Runs around $40.00 for the part.
Aug 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
I have canon 6085 very bad print and code error e012
Hello sir; Looks like the drum motor have problem, open back cover find out drum motor and look around have any gear broke if everything fine then replace motor that is necessary.
Jun 13, 2009 | Canon NP 6085 Copier
CANON 6085 PROBLEMS
No image usually in developer charge area. drum may not be going around, charge coronas (wires) broke, etc. Does it have enough toner. I have seen no image because toner was not installed. Run dark copy and see if you can see anything...
Aug 01, 2008 | Canon NP 6085 Copier
Error code e000014-0000
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Nov 02, 2007 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER C3220 Color Copier Logo
91 people viewed this question
old marine
old marine
