Question about Fujitsu ScanSnap Manager
PDF file cannot be found
Fujitsu ScanSnap scanner is responding to my computer. But after I have scanned a document, I cannot find the file. I was prompted by the message "There was error opening this document. This file cannot be found. Please help determine what causes the problem, and how to solve it.
  • skardos Sep 24, 2008
    Computer responds to scans but the document does not show up on the list of scanned documents.
    Genius:
  • 1,913 Answers
Install acrober reader again and try it.
also u can try to scan document in jpg format.
Posted on Mar 31, 2008
Unable to Scan to print
As from your question it is understood that, you have not correctly uninstalled all the software and drivers related to Fujitsu Scansnap S1500M printer from the computer. So to help you uninstall it correctly and reinstall it again, please follow the step-by-step instructions mention under 'Uninstalling on a Windows OS' on page.no.355. and to reinstall it follow the instructions mention under 'Installing Scansnap Manager on Windows' on page.no.47 from the user manual link given below:
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/s1500_s1500m_ops-guide.pdf
If issue persists, you are advised to contact printer manufacturer from the below link:
http://www.fujitsu.com/global/support/
GuruAid.com
Mar 16, 2016 | Fujitsu ScanSnap S1500M
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
I have a solid line appearing top to bottom down one side on documents after I scan them, how can I remove it
You need to open up the unit and clean all pieces of glass. There is something on the glass causing the line.
Aug 04, 2011 | Fujitsu ScanSnap S1500 Instant PDF...
Neither of my computers will recognize the scanner and I cannot scan a document
you may have to check if the appropriate driver for your printer is installed in your computer. Please find the following link for the driver, please double check, the driver should be according to your operating system.
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s500.html
Jan 10, 2011 | Fujitsu ScanSnap S500 Pass-Through...
I can not scan to folder now, I am using scansnap s510m, please guide how to solve this problem. I am using macbookpro
Click and hold down the mouse button over the ScanSnap Manager Icon in the Dock menu and confirm that Quick Menu is checked.
load the document you want to scan
press the scan button
when scanning is complete the snapscan quick menu appears
place the curser on the scan2 folder
click it in the action list
a preview window appears
You can change the file name and the folder you want to put it in. You can also resize it here by dragging the lower right corner
here is the manual
http://www.fujitsu.ca/pdf/scanners/manual/operator/s510/S510M_Owner_P3PC-1942-01ENZ0.pdf
Dec 31, 2009 | Fujitsu ScanSnap Manager
How do i delete error pages after scaanning?
I changed the settings from duplex (double sided) scanning to simplex (single sided) scanning under the settings tab in the scansnap organiser. this was ok since i had all one-sided documents to scan. you would need to reverse this settings change anytime you have a double-sided document to scan.
Nov 18, 2009 | Fujitsu ScanSnap S510
After scanning the first document and saving the file the scanner will not scan another document. I have to close it and open it back up to scan another document.
your memeory does not allow to scan more than one documents and when you close and reopen it refresh the temp. memory in your system...try to clean all cach and and clean the system or close some of the background applications that is running.
Nov 07, 2009 | Fujitsu ScanSnap S510
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
Computers & Internet Logo
805 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
