Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
It's me again with the Neptune Stackable
It's me again with the Maytag Neptune Stackable Washer/Dryer model number MLE2000AYW. We got the belt on without a problem. It ran a load with success. Before putting the belt on, we checked the bearings and nothing was loose. The bearings, however, were replaced on this machine in 2007, 1 1/2 years after original purchase...I am the 2nd owner. So, it worked for one load this time, and then the belt fell off again. Any suggestions about the potential problem and what should be checked???
Thanks.
  • Bridget Burkot May 16, 2010
    will check if this is the case. Thanks.
  • 11,896 Answers
Check for bent or loose pulleys. Check that belt is not stretched out, Some of these have a belt tensioner. Not sure if yours does or not. If it happens to have one, tighten it and see if that helps.
Posted on May 16, 2010
  • Nate Stansfield
    Nate Stansfield May 16, 2010
    Not a problem. Thank YOU. Let me know how it goes.
How do we replace drive belt in maytag neptune dryer MLE2000AYW stacked unit? The dryer puts out heat but does not tumble....
Go to www.repairclinic.com and enter MLE2000AYW. You will be presented with a list of common replacement parts and may be able to view a generic video showing disassembly from which you can determine the belt installation procedure.
Aug 20, 2017 | Maytag Dryers
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
My Maytag Neptune stackable model number mle2000ayw wont spin nor will the door lock light go on
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch.
In the stackable it is just behing the door lock.
Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color)
To be safe replacing both the things would solve your issue,
If you need furthur assistance, You can leave me comment, i may help you
RNJ VINOD KUMAR
Sep 22, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag stackable
Hello, Welcome
At this site you will find diagrams and schematics for your solution!
http://www.pcappliancerepair.com/model-display.php
Please remember to leave a rating before you leave
Huum
Dec 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
