Question about ASUS A8N-SLI Deluxe Motherboard
IBM 8650 continuous long single beeps
This wkstn makes continous long single beeps. I reseated the mem, vid, cpu, checked cables to mother and all seemed fine still beeped. I systematically removed all these components until there was nothing connected to the mother but the power and it still beeped. I went ahead and replaced the mother and replaced everything back into the new mother and still beeped. I am in need of advise.
  • Trekietechy Apr 02, 2008
    Turned out it was a memory issue. IBM mpro 6850. The memory card must have the memory arranged in a particular order and only in this manner will it work. I found out by prallalel testing it with a identical model.
  • 1,913 Answers
Check your power suply,smps,and also check your motherbord dont touch the cabinet.
also check your processor case and clean it.
Posted on Mar 31, 2008
Dell Checkpoint emem help
Jun 15, 2013 | Dell Computers & Internet
Computrer beeps several times when it starts
Depending on beep pattern it is trying to tell you that you have faulty memory or a graphics card problem.(normally)
If you have been inside your case / moved pc directly before this. Then suggest you gently reseat graphics card.
If you have added memory remove it, reseat original mem.
Dec 31, 2009 | Dell Computers & Internet
Motherboard no responce
When you turn on the PC, normally the boot codes start at 00 and go up to FF (ex 00, 01, 02 etc..).
1.remove the ram memory and video cards if any .. 2. check and reconnect the power suppy wires for mother board , 3. dont worry about your operating system data is lost . 4. if u have not heard any beeps while booting then could be the ic chip ...reseat it properly and make sure it is properly locked . 5. check the fan ...the chip can will over heat when the fan malfunctions ..
this should help ...based on info provided by u , provided u take atmost care while opening or reseating the mobo items
good luck..!
Oct 26, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
No picture and desktop makes beeping sound
Base on the post codes this continuous beeping indicates a power problem. Atypically this is a power supply problem and it will need to be replaced.
Oct 06, 2009 | Computers & Internet
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
Remove a memory module.
If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module.
Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
If the computer has a graphics adapter, remove it.
If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step.
If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
Remove a PCI card.
If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card.
Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket.
If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing.
Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case.
May 12, 2009 | Intel Motherboard
2 short bit continouse
the memory on your system is bad, you have to replace it
Feb 05, 2009 | IBM (25P3294) Motherboard
sounds like a bad mother board, have you taken out the mem and see if it beeps?
Jun 19, 2008 | IBM Netfinity 5600 8664 Server
Boot Problems... Complicated...
The IBM Netfinity 5600 is a complicated beast for sure. You really need to get a copy of the Netfinity Manual from IBM (not on the web site fyi.). It's as big as the machine unfortunately. In section 3, p.124 it lists 3-3-3 beep code as "No memory has been detected in the system" solution is "Reseat mem modules or install mem modules. If prob persists get machine serviced." On the previous page, 3 short beeps (only) on POST indicate "system mem error. combo only occurs when video bios cannot display error msg. replace the failing mem module." You might also want to check the light-path diagnostics inside the machine. A little light will be illuminated right beside the bad DIMM.
Jun 06, 2008 | IBM Netfinity 5600 8664 Server
Video error beep codes not video problem
Sounds like Bad Memory chips try just using one chip. even though youve replaced the video card. so im guessing memory could be bad, at least one of them.
try not reseating them but just using one at a time in the slots
also yeah reseating the CPU can help too, an over heating CPU will still boot up, but not advisable. make sure heatsink is present and fans are working. thermal grease is good too on cpu.
but check memory if you have mixed memory like 128mb and 512mb chips try smaller one first if it works then try the higher one.
but sounds like a memory problem, they can go bad almost instantly.
Jun 04, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS A8N-SLI Deluxe Motherboard Logo
94 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
