Question about Pentair Minimax NT Heater
Smell Gas I smell gas periodically when using the heater for the pool or spa then it will go away. Is there something simple I can check or should I call the gas company?
    President:
  • 1,902 Answers
If you are smelling gas it is advised that you just call the gas company, they come out for free and find out what it wrong. Some heaters will always produce a small amount of gas smell, but most don't. You can check all of your gas lines with a little soap and water and see if you see any bubbles and if you do then tighten that part up.
But you will even need to check your gas valve for possible leaks also
Posted on May 16, 2010
Flame will no light. Replaced the ignightor module
Sounds like the gas valve isnt opening. are you able to smell if you are getting gas into the system. when it goes to light just try and smell gas coming threw the flue. if no gas try and check with a multi meter if the gas valve is getting power to it. also it might make a click noise when the solenoid in the gas valve energizes. also check that there is indeed gas going into the gas valve. it could also have some gunk blocking the gas from entering the gas valve there is a screen that can block with stuff that might be restricting the gas from passing through.
Jun 01, 2014 | Hayward H Series Pool & Spa Heater 400k...
Laars Lite 2
If the heater is "acting normal" with no failure codes and you smell gas, then I would bet it's the igniter. The fact that you smell gas indicates the heater does not have a failure in any of the safety circuits and wants to fire. It is just missing an ignition source or the gas you smell is not making it to the proper place to be ignited. Given these two options it is most often the igniter. Replacing the igniter is not difficult but it is a VERY delicate part and experience in handling it is benificial.
Apr 14, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
When heater is running smell way to much gas
have gas pressure checked if ok check pressure on back side of gas valve also check connections after gas valve
Aug 15, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
Smells like gas or amonia on startup, goes away after 10 minutes
depending on what type of heater you have lies the answer.....newer electronic ignition models have a purge cycle, therefor the smell of gas for a brief few moments
May 26, 2013 | Pool & Spa
Mastertemp 400 NG heater - unused gas smell when firing
Ask the gas company for the conversion kit part part number they used.
Jul 11, 2017 | Pentair Mastertemp Heater
Spring start up of pool. cannot get pilot to light for furnace.
Maybe, but unlikely. The amount of gas that is released to the pilot is pretty small. I assume the heater is outside, where the slightest breeze would blow the gas away. I also assume you are having trouble lighting the pilot and you are wondering if maybe there is no gas, since you can't smell it? It may take a few minutes of holding the button down before the pilot will light, and once it does, you may not be able to see the flame in the light of day. If you wait until dark (or at least dusk) you should be able to see the flame of the pilot more easily. And don't forget to hold the button down for a minute or two after it lights to be sure the thermocouple has had time to heat up. If you release the button and the pilot goes out, you probably didn't wait long enough, but it will re-light easily. I hope you find this helpful. Good luck.
Jun 09, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
All my heater does is click. I can't smell any
Could be a bad ignitor or if it is a new heater the gas supply could be undersized. ether way for almost all heater repairs you should get a qulifyed repairman. It is a box full of fire next to your house.
Sep 30, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Jul 21, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pentair Minimax NT Heater Logo
220 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
