Question about Sanyo DP50747 50 in. Plasma TV
Television turns off by itself. what could be the cause?
  • Denise Majewski Jul 03, 2011
    my hitachi 46" LE46S704 WHICH IS ONLY 32 DAYS OLD, ALSO TURNS OFF BY ITSELF AFTER RUNNING FOR AWHILE.. SHOULD I GET IT REPAIRED UNDER WARRANTY OR RETURN THE TV FOR A NEW TV?
My 2004 rca hdtv keeps turning itself off when i turn it on
I do wish i had more but one thing that will cause a problem like this is spraying air freshener or spray cleaners where the spray can get inside the back of the TV. It will also cause it to pop. Hope its this easy to fix for you, good luck.
spray the cleaning rag then wipe TV clean.
Jun 25, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns off by itself
This is usually caused by a faulty power inverter or power board caused by faulty capacitors. This is what converts and transfers power from your outlet to the device
Jun 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
My 32" G.E. television can
I have had similar experiences. I have a VCR sitting near the television. I found that if I keep the VCR turned on then the TV stops changing channels by itself. If the VCR is turned off, then it starts again. Weird, but it worked for some reason.
Feb 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My tv turns on but it shows colored verticals lines all over the screen then turns off
If this problems,the tv is causing this by itself,not by somebody or something hitting the LCD screen panel by causing the damaging the LCD screen panel itself.If this problems is causing by the tv itself,the T-CON decoder board is dead.This T-CON decoder board sit wright at the middle bottom of the tv LCD screen panel.Replace this T-CON decoder will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Nov 12, 2010 | Sylvania LC260SS8 26 in. LCD Television
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
'95 Toshiba CF32E50 TV turns off by itself
there is a microswitch relay it will be a black square box that controls the power from the transformer ive seen those cause that problem before
Apr 24, 2009 | Televison & Video
BLUE SCREEN THEN SHUTS OFF
cause: tuner i believe will cause tv to not find channels turn blue and turn itself off
Aug 18, 2008 | Sony KP-51WS500 51" Rear Projection...
Flicking chanels by itself
It either has a sticking switch (usually caused by using cleaning solutions on the screen) or the power relay is faulty or the remote control is faulty.
Take the batteries out to check the remote.
Thanks guy9
Jul 05, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Sanyo DP50747 50 in. Plasma TV Logo
956 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
