Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
    President:
  • 1,902 Answers
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
Posted on May 16, 2010
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Pentair 40,000 BTU pool and spa heater. It comes on and then shuts off in about a minute with an error code appearing in the readout. The error code is E05. What does this mean?
The heater is trying to light but cannot. Either the igniter is broken or you are not getting any gas to the igniter. Check to make sure your gas valves are on.
Apr 17, 2011 | Pentair MasterTemp 400000 BTU Pool and Spa...
New jandy LxI 400 natural gas pool heater makes a howlering sound which starts after it runs for about five minutes. The noise starts soft and continues to get louder. The noise is loud. Once I shut the...
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Apr 16, 2011 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Heater will fire, will heat for one hour then shutdown. will get digital read out AGS. can turn heater off, let set for a while turn heater on will heat up for an hour and it will shutdown again.
you didn't indicate exact model but here is what the AGS is for.
Not sure if yours has a combustion blower or not, if so check that it's flow is not obstructed. If it doesn't make sure there are no debries in the flue area. Here is the troubleshooting from their manual. You can download a manual from www.jandy.com
AGS
(automatic gas shut-down)
1. Oscillating pump pressure. 1. Clean filter or identify and repair cause of pump
oscillation.
2. Low gas supply pressure. 2. Identify and repair incorrect supply pipe size or
pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners. 3. Identify and correct loose wiring connections, or
problems with igniter, flame sensor , gas valve, or
ignition control.
Jul 16, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My Jandy Laars Natural Gas pool heater (LJ250N)
Check your heater by-pass valve and be sure it is almost closed. If not that then it will be your internal by-pass. These will force water through heater and keep it from overheating the water inside it and shuting it down. Also check to be sure the baskets are clean and the filter is clean.
Jun 27, 2010 | Zodiac Jandy Lite 250K Btu Natural Gas...
My hayward h series minivolt heater works for about 1hour then shuts down and when started again shuts down after 1to 2 minutes
This is a fault in the control system...prob the high limit switch or pressure valve
http://www.laarsman.co.uk
Miles
Jun 05, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Swimming pool heater
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
303 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
