Question about Brother CE4000 Computerized Sewing Machine
I just rewound the bobbin and now I can't pick up the thread
The bobbin won't turn, I have lost my manual and can't remember how to fix it.
    Genius:
  • 1,116 Answers
You can view and/or download a manual at the Brother Website - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=CE4000
Posted on May 16, 2010
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Feb 06, 2016 | Sewing Machines
I need a manual for singer 7105
If when you put the bobbin in, you can't get the top thread to bring it up, your timing is off. That means that the hook that catches the top thread as it goes around is out of sync. If you have had no experience working with this type of machinery, I do not recommend that you try to fix it yourself; however, any sewing machine technician can fix it for you--it should not be expensive and doesn't take long, and it doesn't have to be a Singer dealer--hooks and how they work are standard for every machine. I believe that Sears will work on any machine. It doesn't require a replacement part.
Jul 01, 2014 | Singer 3116 Simple
Needle will not pick up bobbin thread
Sounds like the timing isn't quite right. Your best bet is to go have it serviced and timed.
Jan 08, 2013 | Janome Memory Craft 3000
I have rewound a bobbin on my sewpro sewing machine. When I loaded the bobbin back in the machine I can't get the machine to pick up the thread to sew again.
Welcome to FixYa. I always try the easiest fixes first - make sure your bobbin is inserted correctly, and that the bobbin thread is securely threaded in the bobbin case (sometimes the bobbin thread doesn't "catch" when you place it in the bobbin case). If all is well in the bobbin area, rethread your machine. Make sure that the presser foot is in the raised position when you thread. If it still isn't sewing correctly, change your needle. These last three steps fix most problems. But, if you are still having problems, look at the thread in the problem bobbin. It should be straight and tight. If it is kind of wobbly and a little loose, you'll need to wind the thread onto a new bobbin.
If are new to sewing, keep your manual close by and refer to it often. Simple mistakes can make a new sewer loose confidence, but it is all part of the process of learning your machine.
Good luck and happy sewing. If you have a sec, please rate my response so I know when I need to work on my responses.
Thanks for stopping in. Ginny
Jan 28, 2009 | Sew Pro QuickStitch SP-402 Mechanical...
The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Nov 18, 2008 | Bernina Virtuosa 160
Brother bobbin tread will not pick up
when i sew the thread keeps cutting help
Jul 29, 2008 | Brother XL-3500
Brother CE4000 Computerized Sewing Machine Logo
64 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
