Question about Denon D-M50S CD Shelf System
I have a Denon UD-M5 that's 10 years old but has been working fine. I have just moved house and I think it was damaged in transit - the CD display just says ERR and I can't open any of the the drives. Can't tune the radio either but that may just be because the antenna is not correctly attached. Help please!
  • ab1962s May 16, 2010
    Thanks but I'd like to know if there is anything else I can try first.
Neither of the earlier responses actually understand the problem. What's much more likely is that, unlike a mechanically stuck drawer or derailed CD, you won't hear _anything_ when you fire up the unit. And, if you switch on the unit with any one of the 'load' buttons (rather than the power button) you'll get an ERR msg for that slot. Our unit was about the same age, so not surprising to see a similar failure. It's a tiny fuse on the top circuit board. The UD-M3 suffers from the same fuse blowing--theirs is labled PR003; on the M5, it's PR004. Look on the extreme right edge of the top PCB for a small orange resistor-looking micro-fuse with a '750' beside it. That stands for 750mA, which is what I went down to Radio Shack (The Source) and bought for $2, along with an inline fuse holder ($5). It's a small screw-together capsule with 4" leads on either end. Solder each end on either side of the blown component and you'll be back in business for under $10 and about an hour's effort.
Posted on Dec 11, 2010
  • 6,487 Answers
This is a common problem with this unit. Because this unit has a Button lock that you need to switch On so this problem wont happen. Ii the lock wasnt on then the transport will have been rattling about the whole time while the postie had it and the whole thing will be mis-aligned. The only way to have this fix is to take the unit to a service center and have the mechanism re-align.
Posted on May 16, 2010
  • Mark Gil
    Mark Gil May 16, 2010
    No problem ,you can try this steps.
    Press the eject button on the player. You will notice that the tray is
    making an attempt to move. Use two fine screwdrivers, and insert them
    into the space at the sides of the tray, one on each side, and gently
    try to pull the tray out
  • 560 Answers
Did you lock the CD trays/changer before transport? I hope you did not transport it with CDs inside. If you did not lock the changer or if it has CDs inside, it is most likely that it is miss-aligned. I couldn't find a service manual so you can try to re-align the CD mechanism. I will keep looking and will let you know.
Cd stuck in Denon CD auto changer receiver. Displays ERR. How can I get out?
As there may be other factors at play that require a more detailed explanation, I would suggest that you seek a resolution through a discussion with a qualified technician. To do this, refer to your operating manual, which should provide a telephone number for technical contact assistance. You can also go up to the manufacturer's website and make contact for advice. www.denon.com/
Mar 05, 2015 | Denon Audio Players & Recorders
Denon update firmware
www.usa.denon.com/US/Downloads/Pages/Product-Updates.aspx
Jun 29, 2014 | Denon DBP-1611UD Universal Blu-ray / DVD /...
CD not ejecting - Denon UD-M50
Check its loading belt. It might be broken or the gear wheel assembly have damaged gear wheels. The fault is with its loading mechanism. Sometime, replacement have to be done.
May 10, 2012 | Audio Players & Recorders
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
I need to find the instruction manual for a Denon UD-M30 CD Tuner. Can you help please?
You can get the manual on the link below. Just click on where it says it is free.
http://safemanuals.com/user-guide-instructions-owner-manual/DENON/UD-M30-_E
Good Luck please rate 4 thumbs and please leave a testimonial
Oct 05, 2010 | Audio Players & Recorders
CD JUMPING
Try looking into the lens (power off) with a magnifying glass. If you see any damage you will need to replace the lazer/lens section as the lens will never be able to read the disc.
If it's clear it's more likely to be an electronic fault.
Aug 26, 2009 | Denon CDR-M30 CD Recorder
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
No Aux on a UD-M30
We had the same problem, found that if you plug your device into "line 2 in" on the back and select tape it worked for our ipod. We had to turn the volume right up on the ipod to hear it though
Nov 12, 2008 | Denon CDR-M30 CD Recorder
Subwoofer
what do i need to connect a subwoofer to my Denon UD-M31
Nov 15, 2007 | Denon D-M31S CD Shelf System
DENON UD M50 CD PLAYER no longer works
Maybe you accidentally break some contact(s), on display or somewhere else. If that is the problem, soldering iron should solve that. Look for any loosen wires or detached contacts.
Oct 10, 2007 | Audio Players & Recorders
Denon D-M50S CD Shelf System Logo
2,659 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
