Question about Estate EED4300TQ Electric Dryer
Whirlpool estate electric dryer model eed4300sq0 is noisy (louder than normal). This dryer has always been loud since new, but recently the normal loud hum while it is running has become louder and it reverberates at a steady frequency. I have disassembled it for inspection, did not see anything obvious. The rollers spin, the blower fan is ok, no lint clogs, tensioner seems to have tension. Dryer is 4 yrs old and other than the noise it still works ok. Any ideas???
  • 61 Answers
SOURCE: my whirlpool estate dryer tub will not rotate
To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Posted on Jan 19, 2009
dididsaythat
  • 291 Answers
SOURCE: Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Posted on Sep 17, 2007
jsrock516
  • 5911 Answers
SOURCE: CANT FIND MODEL OR SERIAL NUMBER ON DRYER
There should be a nameplate along the door opening. This is normally where Whirpool puts their information. Just open the door and look along the door or door frame opening. The nameplate data can also be located along the back of the operator console on some models. Let me know if you still can't find it. I hope this helps.
Posted on Nov 11, 2008
protek480
  • 1714 Answers
SOURCE: putting the belt tensioner back on an estate dryer
Watch this:
Posted on Jul 04, 2009
dragonsthatk
  • 547 Answers
SOURCE: Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
Hotpoint CDT00G Very Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 16, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
I have a noisy Maytag LDG 7500 gas dryer.
thats your blower wheel.pop the hood take off the frount the blower is at the bottem.if you are able to turn it and the drum dose not turn thats your problem
Dec 31, 2008 | Maytag PYE2300AY Electric Dryer
Fisher and paykel dryer works but very noisy
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Nov 11, 2008 | Estate TEDX640JQ Electric Dryer
Estate EED4300TQ Electric Dryer Logo
222 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
