Question about Dell Latitude D600 Notebook
Dell D600 laptop
I was signed on and i just lost all power. I had it plugged in and i had the battery in it also. now when i plug the power adapter in to the back of my computer the light on the adapter goes off. (the light is on before i plug it into the laptop) also it will not power up with my battery i have two batteries one had 3 bars and the other 4bars still it want power up.
  • rungunnathan Oct 19, 2008
    I have a similar problem with my D610. Plug AC adapter into wall plug and the light comes on the adapter. Plug the jack into the computer and it goes off. The battery is fully run down. I tried a adapter from another computer (dell inspiron) which had the same output ratings and got similar results. Is there a fuse in the d610? Does it have a power module that can be replaced?
    Any pointers will be help ful
    thanks
    rungun
Try pulling out the battery and the plug the adapter into the laptop. See if you can power it on then.
Posted on Apr 01, 2008
Dell latitude runs but does not boot up
Remove battery + power cord from AC adapter. Wait 10 minutes. Plug in only the power cord. Power-on the laptop.
If laptop starts correctly, plug in battery while it is up using the adapter. Leave on for battery to recharge.
Oct 19, 2011 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
I have a dell latitude d600 when i press the power button with the battery in(just the battery) nothing happens. when i plug the adapter in with/without the battery power comes on and the hd light flashes...
Can you hear the fans starting up.....if you can plug your laptop into a external monitor and see if you can see it boot up...it sound as if you may have a short on the battery pack...
Apr 02, 2011 | Dell Latitude D600 Notebook
My dell d600 will run on batteries ok. I own 3 ac adapters and all flash green when plugged into computer. I removed battery and it still won't power computer it's like something in computer is shorting...
Most likely, if 3 different known good AC adapters will not power the system, then there is a problem with the DC in power jack on the motherboard. The easiest fix is a motherboard replacement (about $100 on ebay)
Dec 19, 2009 | Dell Latitude D600 Notebook
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
My dell latitude d600 won't recognize the AC power adapter and doesn't show that the battery (which is new) is charging. I had to leave it plugged in for about a week when I put in the new battery before...
There was a class action suite against Dell for this problem with this model laptop due to overheating and destroying the power supply. Browse the web for more information. I have one and it is a parts machine now.
Jul 29, 2009 | Dell Latitude D600 Notebook
My latitude d600 will not start.
Is the connection on the Laptop loose? Most power connectors are soldered onto the motherboard and are notorious for becoming loose. If the connector is loose you it may be shorting out the adapter. I would have a professional look at it before plugging the adapter back into it. If you are shorting out the adapter it could present a fire hazard. Most laptop repair companies will resolder the connector for around a $100.
Jan 27, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Latitude D600
remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
Feb 08, 2008 | Dell Latitude D600 Notebook
Dell D610 Batteries don't charge when AC adater is plugged
this is usually a sign of a common problem with these laptops. Usually the power works but it will not power the batteries to charge them. If the power adapter is fine- you have a bad motherboard.
Nov 23, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
Alun Cox
