Question about Ford Garden
Belt for Ford YT16 riding LAwn mower. The one that powers the deck. The old one is shredded. Need replacement number.
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
  • 14 Answers
SOURCE: murray riding lawn moweer Need a diagram of how to attach a drive belt on a murray riding lawn mower 425613X8A DIAIGRAM
search google for diaigram
Posted on Sep 22, 2012
I need a deck belt for my Murray riding lawn mower model number is 13an772s058
If you still have the old belt, even if it is broken. Taje it to your local lawn and garden center that sells parts and service on riding mowers. Have them measure the belt length and width. If the belt is missing, have them look up belt for the model number of the mower you have.
Oct 13, 2015 | Murray Garden
Belt routing diagram
if you type in the model number of your particular mower, you should be able to find a replacement manual, and or you could click images and it may show you a page with your belt breakdown as a picture
Jul 18, 2014 | Huskee Tractor Replacement Riding Lawn...
Need to know what size deck belt it takes for a roper lawn mower the model number is yT140Dr
Electrolux 532106085 (replaces 106085X) BELT-V.79.1.MWR : This is the OEM belt number for the yT140Dr mower deck. Length = 79.1" ; Width = 0.5" (1/2").
Welcome to VBELTS4LESS COM Belt Supplier For Industrial Belts Lawn...
The above link is for VBELTS4LESS, an excellent web site for belts. I've used their belts for two mowers, and the belts are excellent...
Jun 15, 2014 | Garden
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
Craftsman 19.5hp 42 drive belt shredded
most likely the belt was put on the wrong side of the belt retainer clips on one of the two pullys. I've done the same thing more than once. Make sure on next belt there are no sharp edges touching anywhere and while engaged or not.
Oct 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
Jun 29, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
965 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
