Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Fan does not work
Remote turns light on and off but when I try to turn on fan (at any speed) I hear a click noise but it does not turn the fan. Please help.
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
  • 89 Answers
SOURCE: Hunter Fan
check your remote sensor inside the fan housing and make sure it's wired properly. Sounds like the solonoid is not wired correctly to the light. Hope this helps. Good luck.
Posted on Aug 25, 2008
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Hunter 52" ceiling fan model 23457-380, the remote lights up
check the hard wiring from the factory. Where the light kit attaches to the fan check the wires in the factory cubes to make sure none are coming off. I had a similar problem that kicked my **** for a few minutes but I saw a loose wire after a bit of research. My fan also clicked but never turned on. Also pull the chains on the fan/light to make sure they are on. Hope something works for you.
Posted on Aug 21, 2009
hondakilla
  • 129 Answers
SOURCE: Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Posted on Aug 23, 2009
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
My Hunter Fan stoped working. The light works but the fan does not work on any speeds. I hear the fan click when I press the different speeds on the controller. My grandaughter was here and kept taking...
If you hear any humming from the fan when you're trying to turn it on, then your motor is froze. I'm thinking from your description of being able to hear the actual fan switching but getting no results, it's probably the motor.
Aug 28, 2017 | Hunter Ceiling Fan Remote Receiver...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Hunter remote 85752 does not work
You probably need to re-sync the remote to the fan. To do this, turn the power off to the fan; and within ten seconds, hit the "3" button, then the "2", and then hold the 1 button until you hear a click. This should fix it. Good luck!
May 06, 2010 | Hunter 27185 Remote Control
HI, We have a Hunter Ceiling fan with light (5yr. old) The light nor fan will turn on with switch or remote, the fan does click can you help
you probably have a loose/broken wire.
This sometimes happens where the fans wires are wire nuted to the homes wiring in the junction box.
What exactly do you mena when you say the fan "clicks"?
You hear a click when you pull the switch?
or it makes a continuose clicking noise when you have turned it on, but does not turn?
Dec 06, 2008 | Heating & Cooling
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
