I am unable to print 6x9 envelope on my multi-task printer -
  • 2 more comments
  • floridian204 Apr 01, 2008
    No, still having the same problem.  As I mentioned to Max this morning, I am using OSX 10.4.11.  The size envelope I usually use is 6x9.  I also have a smaller size, but I have not used that size since I purchased a new computer in December.  I have been able to print the 6x9 envelope back in Dec. & Jan. When I went to print one on Friday I was unable to do it.  It prints as though it is printing on an 8-1/2x11 piece of paper.  Max said I had all the correct settings.  He even had me install a new printer driver.  My projects are done in Print Explosion Deluxe 3.0.1.1.
    Appreciate any help you can offer to resolve this problem.
    Thanks.
    Elena Fischer
    As I have mentioned earlier, according to Max, and even before I called Canon with the problem, all of my settings for both the computer and the printer are correct.
    Unfortunately, there is no setting for 6x9 envelope so I have to use
    "untitled - 6x9"
  • floridian204 Apr 02, 2008
    Thanks for all of your help.  It's a lot more work for me to do with the envelope in setting it up so that it fits on a #10 instead of a C5 which I used on my previous printer, Lexmark, and also remembering to put in enough envelopes since it has to feed thru 2 envelopes in order to get one typed envelope.  Why not a C5? This is what I used for 5 yrs. with the Print Explosion and never wasted a single envelope, ever.  Since last Friday I must have ruined at least a dozen  envelopes.   Oh well, thanks for your help.
    Have a great evening!
    floridian204
    Sergeant:
    Champion:
  • 326 Answers
U must isolate problem to printer or program. What program? Does printer work for other sizes?
Posted on Mar 31, 2008
  • 1 more comment
  • Rory Biggs
    Rory Biggs Apr 01, 2008
    Check Ur default settings for the printer properties, along with the program envelope sizes. Sounds like it prints, but wrong size.
  • Rory Biggs
    When U call the envelopes & labels, check Ur options and set it to the envelope U are wanting.
  • Rory Biggs
    Rory Biggs Apr 02, 2008
    One thing U may have tried part of this is -
    Uninstall the printer
    Turn off the printer for at least 10 mins
    Reboot
    Turn on the printer.
    Reinstall the printer and use the orginal drivers.
    Cannon printers are usually good printers, maybe U've had a power surge and it has messed the software up. It really strikes me that it's a setup of the Print Explosion software.
    Good Luck
Not printing envelopes and printer locks up
Use a small flash light and check for any debris blocking the roller from the tray...
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
I am unable to print a 6x9 envelope.
Make sure you:
1: adjust paper size on printer and in the program.
2. pull levers toward envolope on feeder.
If you did all of this then chances are you have a bad feeder sensor and the printer would need to be repaired but I am quite sure this is not the case.
Thank you
Sep 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer always refuses to print a 6X9 envelope by showing the message "paper mismatch,Press OK to cancel job".
go to the printer's preferences, and change the paper size. also be sure you are putting the envelope on the correct side of the printer's paper tray. It should have a small picture showing you the way it should be facing, etc.
Aug 14, 2009 | Office Equipment & Supplies
Unable to print #10 envelopes on my Xerox WorkCentre 7675... I am using Microsoft Word and selecting the Bypass tray, but I'm still unable to print on these envelopes. Are there any other solutions?
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Jul 31, 2009 | Xerox Office Equipment & Supplies
Samsung clp-300 printer feed problems
Samsung has alot of problems with this printer.
Jun 12, 2009 | Office Equipment & Supplies
Printing #10 Envelopes in a Minolta CF 2002
You can print #10 envelopes in ANY printer. Use the bypass (or multi purpose tray).
May 04, 2009 | Minolta CF2001 Copier
Half-envelope error 41.3 or just won't print
If your getting a 41 error the printer thinks a different size is coming. For example the printer is expecting 81/2 and you are sending 11.
Make sure the printer is set to the proper size not only the progam you are sending from.
You can set tray 1 to CUSTOM or ANY and see if it helps.
hope this helps.
Mar 07, 2009 | HP LaserJet 5100tn Printer
Envelopes
you sure you have the model correct???
as far as I know Sharp DM-3551 is multi-task machine but, it is not capable of printing envelops.
Oct 17, 2008 | Sharp DM-3551 All-In-One Printer
Printing envelopes
You may have to go into the printer properties and change the size in the paper size drop down list, Your printer thinks that you are trying to print the envelopes on standard size sheet of paper, if you change that to the 6x9 in the printer properties it should work for you now, If it don't just write back here and we will try something else. Happy Holidays
Dec 12, 2007 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
