Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
MONITOR COMES ON MAYBE 4 2MIN AND THAN GOES DARK
    Problem Solver:
  • 9 Answers
Are you seeing anything on the monitor??
Posted on May 16, 2010
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
Screen comes on then goes dark turn it back off and same thing comes on and then goes dark you can barley make out imagies on screen
If you plan to DIY repair, then please read below and look at the pictures at the link I provide so you will know what to look for inside the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 10, 2010 | Computers & Internet
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Screen goes blank after a second
More likely to be transistors.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Check the solder joints, fuse, transistors (c5706/5707), caps and look at other Dell albums also.
Replacement bd: www.lcdrepair.us
Apr 29, 2010 | Dell E153FP 15" LCD Monitor
Screen comes on then goes dark , turn it back off and same thing comes on and then goes dark you can barley make out imagies on screen
Most monitors failures are caused by failed capacitors in the power supply/Inverter board, you need to open it up and inspect for caps with bulging top/seal, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find inside so we can guide you further.
Mar 18, 2010 | Computers & Internet
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Scceen flickers on and off
You'll have to describe the problem in a bit more detail, because it could be a couple different things based on when it goes dark and what "dark" means.
I'm going to guess that the monitor is turning itself off after that second, but you might be describing that it doesn't say it's off, but there is no image (or maybe a really faint image that you can see in the bright light). Try checking it in the bright light after it goes dark. Also, does it seem different if you bang on, shake, or turn it upside down. Don't do this if you haven't already as it will more likely damage it than fix it, but if you have already banged on it, does it change?
I'm working on the same model with a similar problem (not sure it's the same) and will be ripping into it soon and will post the results.
Nov 02, 2007 | Liquid Video A170E101 Monitor
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
328 people viewed this question
Alun Cox
