Question about Oreck XL Ultra Bagged Upright Vacuum
Changing the belt
How do i change the belt. i have no manual can you give me step my step
    Sniper:
  • 52 Answers
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
Posted on May 18, 2010
HOW do you stretch the belt to make it fit?
Posted on Aug 21, 2010
Need to change belt
click the link below for the manual it will give you step by step instructions how to change the belt,
http://www.eureka.com/FileLibrary/7f8e42f94c4146dea58673f01e6464a7/en_80509_OwnersManual.pdf
Aug 19, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I need a replacement belt for Hoover Elite upright vaccum ,model no. U5043-930. What belt do I get?
Your vacuum cleaner originally came with Hoover belt part number 38528027, however Hoover has now discontinued this part number, and replaced this belt with the new belt which is part number 38528040.
The new belt is a little bit smaller then your old one, but unfortunately this is the only belt that Hoover currently makes that will fit your model.
Here's a direct link to our website if you still need to purchase one:
http://www.govacuum.com/agbelhoovpar7.html
I have also uploaded the parts diagram and instruction manual for you. The parts diagram gives you every single part number for all parts on your vacuum should ever need to know another part number. The owners manual will give you step by step instructions on how to change the belt, as well as other maintenance instructions.
Part Diagram for Hoover U5227-930:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/Part-diagram-hoover-u5043-930.pdf
Owners manual is actually for the commercial version of your vacuum, but this will be identical to your instruction manual which Hoover doesn't have available for free:
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you. If it was, please be so kind and rate my repair helpful by clicking the thumbs up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U5227-930 Elite Upright Vacuum
Broken belt on infinity vacum
You may find the belt for your vacuum through the link below. Unfortunately the only way that Shark sells this belt is with both belts as a set, you can not purchase each indiviudal belt separately.
I have also uploaded the instruction manual for your vacuum in a .pdf file on Fixya. Please note that it may take sometimes up to 24 hours for the manual to show up. Please check the following link over the next 24 hours. This instruction manual gives you step by step instructions on how to replace the belt, and also contains diagrams that will help you follow along.
Here's the link where the instruction manual will be downloaded. The belt change instructions are on page 15:
http://www.sharkclean.com/manual/NV31_REV_0706.pdf
Here's the set of belts that go on the Euro-Pro Infinity Upright model NV31, Shark Part Number 1085F:
http://www.govacuum.com/eushrebesetf.html
I hope this was helpful to you in solving your belt problems. If this was helpful please rate the repair helpful by clicking on the thumbs up icons in the top right hand corner of the repair.
Chris Jones
GoVacuum
Mar 25, 2010 | Euro-Pro NV31 Infinity Vacuum
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
How do you change a burnt belt for hoover u5269
If you go to this link you will find the belt you are looking for and you can also view the manual, which has step by step instructions on how to change the belt. Good luck!
Hoover EmPower U5269910 Belt and Manual
Oct 26, 2009 | Hoover U5269910 Bagless Upright Vacuum
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
http://www.vacbelts.com/bissell-lift-off-revolution-pet-vacuum-belt-.htm
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing belt Please advise how to change the belt. I wasn't the person who took the belt off, didn't watch. Now it's just me and the belt. I had 2, but 1st one burnt right off. Apparently I didn't have...
place
end cap into base.
IMPORTANT
position belt.
two screws.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Oreck XL Ultra Bagged Upright Vacuum Logo
457 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
