Question about Tascam DP01 All-In-One Recording Package Microphone
Mastering the songs
Hi. I have a dp-01fx/cd and to me the owner's manual is very confusing. I have recorded about 10 songs using track 1 and I cannot burn a cd. When I try to master the songs the equipment tells me that the song is too short. I tried to download the beginners manual for recording from the Tascam site but it doesn't let me do it. I am new at this and there is a lot of jargon that I do not understand in the manual. Please help.
    Problem Solver:
  • 19 Answers
You’re trying to master with the OUT point at the zero position.
Set the OUT point and try again.
Check chapter “IN and OUT marks” on page 29 of your manual if you don't know how to set the 'in' and 'out' marks.
Posted on Mar 31, 2008
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Problem with dp001fx/cd
You have to set the in and out points before you master
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Is there a good tutorial avail? I lost all my music trying to create a cd without finalizing or mastering!!!! Panic took over and i rushed to undo without fully understanding what i did exactly. No...
You can download a manual from the tascam site for this model. as long as you pre-named your songs, they should show in the menu without mastering. You cannot burn any songs without mastering your songs first, however. They will not appear in the create cd section for this very reason.
Record, master,burn.
Jan 05, 2011 | Tascam 2488mkii 24 Track Recording...
How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Nov 11, 2009 | Tascam Dp-02cf Digital 8-track Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
BD
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Mar 31, 2008 | Tascam DP01 All-In-One Recording Package...
If anyone can help me out,please do!
Alternatively you could load your stereo instrumental track into a wav editor, then export each stereo track as a separate mono wav file which you can transfer via usb into you DP-01 and then on you DP-01 import those wav files into two separate tracks which you can pan hard left and hard right so they are in stereo.
Dec 28, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
153 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
