Question about Acer Extensa 5420-5687 Notebook
My Acer Extensa 5420 will not power on. Battery light will illuminate when plugged in but ince you hit the power button the laptop will start to power up for about 20-30 seconds, you can hear the cd/dvd drive and such but nothing on the screen. It will back down and that is it. Maybe battery? RAM? Really not sure. Worked fine before this problem. Thanks for any help.
  • srphlp May 16, 2010
    The laptop will only power up for about 20 seconds and the only led's i have is the battery led and briefly the power button. Nothing appears on the screen at all.
    Thanks for your time on this. I'll try the battery and then go from there.
  • 4,281 Answers
First open back cover of lapltop then reattach both battery and RAM memory.
Then check.
when you power up the computer check num lock led if it is on and off when you press num lock key then your ram is working fine then you need to change screen resoluion.
For that when you power up the computer press F8 key if you are able to see safe mdoe and other menu then enter in "enable vga mode" then go to display property and change screen resolution to 1024*768 then apply.
But if num lock led is constant then you need to change ram.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 16, 2010
  • So try with another battery if still not work you need to repair your laptop at nearest computer service center.Because it has some internal motherboard chip related issue.
Acer extensa 5420 bios
Clean out the cooling fan/vents, etc. and try again. If the fan isn't turning, it won't boot up.
If that doesn't work, you may need to disconnect the power supply and battery and then hold down the power button for 30-60 seconds. This will discharge stored energy from your laptop. I'm not sure of the specifics, but this happens to mine every 12-18 months or so. Once you've done that, reconnect the charger and battery and try to power up again. It should work now.
If these steps don't fix it, you have serious problems.
May 02, 2014 | Acer Extensa 5420-5687 Notebook
Acer Extensa 5235 wil not power on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Extensa 5235 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Extensa 5420-5687 Notebook
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
I have an Acer Extensa 5420-5687 laptop that is not powering up. When the laptop is running off the battery and I try to turn it on, the power light and the disk light flash for a few seconds, then it...
pretty much motherboard is trash, I had the same promblem and tech told me it will cost over 150 for replacement parts and 75.00hr + labor fee. I just said hell with this!
Feb 21, 2010 | Acer Extensa 5420-5687 Notebook
Will not start on battery or plug-in to wall outlet - when holding down the power on button to start - nothing happens
Take out the hard drive and dvd drive and also make sure the battery is out. Plug in the AC Adapter and then see if the laptop turns on. If it still doesn't turn on then that means the motherboard is bad.
Dec 17, 2009 | Acer Extensa 5420-5687 Notebook
I have an extensa 5420-5687. 1 day my laptop just
the power cord has shorted out you will need to buy a new one
If I have helped you please click the yes this was helpful button
Dec 03, 2009 | Acer Extensa 5420-5687 Notebook
Acer Extensa 5420 won't turn on, not a power/battery problem.
Just for the heck of it, try blowing out the cooling fan with some compressed air. If you have never cleaned it and the fan stops turning, the computer will go into a safe mode and not start up.
Ther should be a vent somewhere on the side of the laptop that vents hot air cooling the CPU. That is where you need to blow it out.
Hope it helps- just a longshot...
May 26, 2009 | Acer Extensa 5420-5687 Notebook
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
Acer Extensa 5420-5687 Notebook Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
